4 speed pedal mounting bracket
Hey,
Hopefully one of you guys can shed some light. I am doing an automatic to 5 speed conversion on my 1968 cutlass and someone had said that the pedal mounting automatic bracket will not work with the new pedal assembly. Is there a different bracket for the 4 speed? He also said I should go with a chevelle setup but didn't have time to ask why?
Thanks in advance - you guys are great.
Anyone? Part #'s?
Rich
Anyone? Part #'s?
Rich
Hey,
chevelle pedals use pin type with a clip
BOP uses a nut and bolt..
Chevelle is chevelle...you must use the entire assy with pedal hanger to use a chevelle type in a BOP car
BOP cars ya do as Joe said...unbolt and bolt it in...the bolt is longer for manual pedal cars
look at Ames pontiac parts..they sell the correct pedals..a buddy just bought a set for his GTO and they are very good....they came with all the hardware...so i would think you can buy the bolt and and nut..the nut is swedged/locking
Tbere isn't one on a '68! People were expected to pay attention back then!
Seriously though ....you could use the 69 and up parts if you really want one. Just tie it into the AT neutral start safety circuit.
my 68 cutlass has a chevelle assy in it right now..i had it all from a 68 4 door i parted..so i used it all..bolted right in..ive also put chevelle in sklarks...many times...never tried the cutlass skylark thing...never able to find that stuff around here or where i grew up
Pedals work but the hanger bracket did not. I have a 72 Skylark that had a chevelle hanger bracket (poorly) jammed in it. All my other stuff is Olds. Had a 70 (and a 68) Cutlass hanger bracket that would not fit without mods. Found a 71 Skylark hanger at the junkyark. Rather not take the dash apart to take side by side pics,
rcdynamic88
Brakes/Hydraulic Systems
August 6th, 2014 07:41 PM
