330 HEI conversion
Old May 8, 2019 | 09:48 AM
1988coreym's Avatar
330 HEI conversion
I will soon be replacing the 307 in my 1986 Buick Regal with a 330. Would like to convert it to HEI. Thought about leaving the points on it. But I won' have a resistance wire in the Buick. What are the easiest and best options for this ?
Old May 8, 2019 | 09:52 AM
You can use a ballast resistor in place of the resistance wire.
https://www.summitracing.com/parts/s...mpaign=Brands+ +S&utm_term=4582077271759650&utm_content=GSAPI+5ba 29e8f8c24c
An Hei is also an easy drop in.
Old May 8, 2019 | 10:02 AM
Or, you can just replace the points distributor with any Oldsmobile HEI distributor. I ASSUME you are no longer using the CCC system, correct? If so, be sure to get an HEI distributor with a vacuum advance can. The ones without vac advance only work with CCC.
Old May 9, 2019 | 05:46 AM
1988coreym's Avatar
Yes. I am getting rid of the CCC. I am running an Edelbrock 1406. Any Brand suggestions ?
Old May 9, 2019 | 07:23 AM
Well, GM comes to mind. Get a used factory HEI, install a new module, cap, and rotor, and stab it in.
Old May 9, 2019 | 08:03 AM
1988coreym's Avatar
Ok Thanks
Old May 9, 2019 | 12:22 PM
1988coreym's Avatar
Just ordered a HEI Distributor from Summit. I will let you know how it works out. Thanks for the help.
Old May 10, 2019 | 07:40 AM
bry593's Avatar
1968 442 Convertible
As Joe said, an old GM dizzy is the hot ticket. Summit distributors are entirely Chinese these days. I recommend disassembling and soldering each connection. It is not uncommon for these cheapos to have poor crimps resulting in sporadic no-start. These also have issues with mechanical advance stops and sometimes the coil only fits chinese caps.
Oldracerjones
Mar 1, 2016 08:50 AM
angelo68442convertible
Dec 8, 2015 09:10 AM
redoldsman
Aug 9, 2014 09:51 AM
oldsmobilty
Aug 8, 2013 12:19 PM
Wyze
May 14, 2010 01:29 PM
