1972 442 broadcast card, do I have enough proof
Okay I just bought a 1972 442 convertible, 350 car. I found the broadcast sheet in the back of the bucket seat. The hog nose ring went through the "2" area, on w-29. I am attaching pictures and would like and opinion if it is a real 442. You can still make out the 2 when you blow it up, that picture attached also. I believe it is a 2 anyway. The last 6 of the vin is not on the card but the body numbers are the same. Is the w29 in the correct block also. I am going to keep looking for other proof.
Appreciate any help.
Kelly
Kelly
w39
http://automotivemileposts.com/oldsmobile/rpocodes.html
according to this website there is a w39, 3 speed hurst shifter. I am taking that as dual gate and the car has one. The number looks nothing like a 3 to me. The dual gate may have been added to the car, a few things have been done to the car. The car shows no signs of cutlass supreme trim down the sides or any rocker molding.
Kelly
Kelly
Kelly
Kelly
Terry
any ideal what the red tag was for? I see it on another guys picture in another discussion. No writing at all on my tag.
Also my car has the dual gate, should it have been on this boadcast card?
Thanks for the help proving the car is a 442. I fealt like the car was a 442 but paperwork is the only proof for this car.
Kelly
Kelly
That is the correct location for W29 so if the body number matches the cowl tag as you say then Terry is right. It is definitely a 442 and not much else can top that document. I suggest protecting it dearly.
Kelly
Kelly
Sam
Correct, the W26 was listed on the build sheet in box 107. Note, this isn't the build sheet for a 442, but it is a rather good example of a special order Cutlass S with a U code engine and code 19 paint.
Here's an example:
Here's some other documentation you don't often see for a 72 442
Here's an example:
Wow Alan, would love to have that documentation for mine!! What determines which options are on the card vs the sheet? My 72 is a factory OAI, rallye pack car. The hood doesn't show on the card but the U20 (I think) for the gauges does. It was built in Lansing so I won't be spending any time looking for a sheet. Actually have 2 cards including one that the PO provided and one that I discovered on the pass side under the sill plate between the front and back carpet. Anyway, great discussion in this thread.
halfmoontrail
March 6th, 2015 09:28 AM
