1970 cutlass 4 speed
Old Mar 3, 2020 | 02:15 PM
Dean A Hintzman's Avatar
Has anyone ever come across a 1970 cutlass s with a 4 barrel and Hurst 4 speed. This is a non ralleye car. Hurst logo is on the left trunk lid.
Old Mar 3, 2020 | 02:27 PM
I assume you are referring to an aftermarket emblem similar to the ones in these posts:
https://classicoldsmobile.com/forums...quipped-77842/
https://classicoldsmobile.com/forums...mblems-132300/
Old Mar 3, 2020 | 02:40 PM
More interested in if anyone has ever seen a stock 1970 cutlass s with a hurst 4 speed and 4 barrel. Thanks.
Old Mar 3, 2020 | 04:10 PM
I saw one once at a car show, and as a matter of fact my 70 Supreme convertible is a 4 speed, purportedly one of just a handful built that year.
I remember the car at the car show pretty well. It was sort of a tomato soup color and just as the guy was getting ready to leave all the coolant came out of the engine and ran down the parking lot. He just sat there bewildered.
Old Mar 3, 2020 | 04:19 PM
442Harv's Avatar
Yes I have seen one. Years ago, at are local Nor Cal Olds one showed up, first and only one I have seen, also had bucket seats.
Old Mar 3, 2020 | 04:43 PM
lunaboy's Avatar
The Rocket Astronomer
I saw one in my driveway a few years ago; 4 speed 4 barrel and ac to boot.
Unfortunately, i sold it not realizing the rarity and choose a 442 to restore.
This 4-speed cutlass S was gold with gold bucket seats and the original owner use to race it at San Antonio speedway.
It had a 3:42 rear because of the ac so the guy opted to put in a 3:90 gear set. with that M20 he said it got along fine.
when i purchased it the original 350 was in the trunk and he had a built 403 in it.
Old Mar 3, 2020 | 04:58 PM
70W-32's Avatar
I dont believe they came with a Hurst Shifter, that would have been an aftermarket add on, and the emblem came in the box with the shifter. Manual transmissions were available in small block powered F85/Cutlass/Cutlass S/Cutlass Supreme Models. 455 equipped cars came with auto trans only.
Old Mar 3, 2020 | 05:24 PM
marxjunk's Avatar
as far as 4bbl and a hurst shifter yes..i have had 3..all 350 4bbl, and a Hurst shifter was all that was available from GM...its not really special, but they are cool
i even had one that was a 350 4bbl with a 3 speed manual and a console..and the Hurst shifter was standard equipment..not really special..
hurst emblems where for hurst wheels originally...not a hurst shifter...the originals are pot metal, and they are repopped in plastic, and have been repopped for a long long time..in the late 90s they started showing up on hot rods because they where just so freakin cool
the embs say Hurst Equipped...i assume thats what you are talking about??
Old Mar 3, 2020 | 05:26 PM
66SportCoupe's Avatar
Restored a 1970 Cutlass Supreme Convertible with 350 and factory 4 spd also had rally suspension. Had Hurst shifter with just a H on it. This car was platinum met. Black interior with AC. This car had it's factory build sheet.
Old Mar 3, 2020 | 08:25 PM
vette442's Avatar
They’re out there with both M20s and M21s in 1970. The ones that have become really desirable have the hotter QB code 350 in them. Do a forum search by “QB” and you should see some informative results.
As others have mentioned, they’ll have a Hurst shifter with just the “H” on it.
Terry
Old Mar 4, 2020 | 07:17 AM
The 350 4bbl 4spd was readily available as a factory option in 1970 (and in many other years). All Muncie transmissions from 1966-1974 came from the factory with Hurst shifters in Oldsmobiles. All would have had the "H" stamped in the stick. The easy way to tell if the shifter is factory or not is to remove the boot. Factory Hurst shifters use a snap-in stick. Aftermarket ones use a bolt-on stick.
Old Jul 10, 2020 | 06:28 AM
therobski's Avatar
Maybe next year, 2021 I'll long haul the F-85 up your way out of Dallas if the weather forecast is decent for late November. It would be an exciting ride. Afterwards I would run up to Wisconsin and see family.
Old Jan 1, 2021 | 05:05 PM
Pictures Pictures. Pleeaase...
Old Jan 2, 2021 | 02:03 PM
Ctls442's Avatar
Here's a few pictures of one that has been hibernating in a dry building since the mid 1980's. Lansing built very late in the model year, it has the QB code 350.
Old Jan 2, 2021 | 02:36 PM
I love it! Your car?
Old Jan 2, 2021 | 08:03 PM
Mr Shifty Sidney's Avatar
Is that Oldsmobile's version of houndstooth interior? Cool car
Don W
Ctls442's Avatar
Thanks for the comment.
Yes, it is my car.
Old Jan 2, 2021 | 08:09 PM
That color no top is one of my favorite colors on an Olds A body. I knew of a 70 442 with factory ram air in that color. Beautiful car. Good for you. It is sitting indoors. Let it sit until you can get to it. Awesome car. Love to hear details on it. What a kick *** car. Can I say that here?
Old Jan 2, 2021 | 08:10 PM
Ctls442's Avatar
Don W
Don, Yes, it is "1 of 1" with these rare seat covers.
Old Jan 2, 2021 | 08:19 PM
White interior too...
I LOVE IT!!
Old Jan 3, 2021 | 12:33 PM
Ctls442's Avatar
The car appears to have been originally ordered to mirror a W-31 based on the 17 options on the car, including performance options such as high compression 350 with 4 barrel, W-25 ram air hood, four speed, dual exhaust, anti-slip rear, heavy duty suspension with sway bar, etc... The car does have power brakes which you could not get on a W-31. Maybe the original owner wanted power brakes along with performance. I should do an owner history search as it would be interesting to find out from the original owner what the motivation was to load up a Cutlass S with options as opposed to buying a W-31.
Old Jan 3, 2021 | 12:41 PM
Because it has the 310 HP L74 motor and the 286/286 deg cam and not the 325 HP W31 motor with the 308/308 cam.
Old Jan 3, 2021 | 12:53 PM
Ctls442's Avatar
Yes. The non-QB version of the 350 with 4 barrel (also rated at 310 HP) had the 250 cam.
Old Jan 3, 2021 | 01:17 PM
Ctls442's Avatar
Here are pictures of another 1970 Cutlass S, with a QB code 350 and factory four speed. Owned by a friend of mine, this car is twilight blue, with black bucket seat interior. Tucked away in 1990, alongside his '68 442 convertible, in less than ideal storage conditions.
Old Jan 3, 2021 | 06:20 PM
At least it is covered. Shame cars like this never see the light of day. Just sit and rot. Maybe hopefully some day.
Old Jan 6, 2021 | 07:43 PM
Bigmikey65's Avatar
I was perusing Mecums Kissimmee 2021’s listings. Lot #R105.1. Blue/blue ‘70 Cutlass S 4-speed with buckets. I did not see any mention of condition or documentation. Looks like a nice driver.
Old Jan 7, 2021 | 01:17 PM
Bigmikey65's Avatar
Without seeing the ‘70 blue/blue up for auction at Mecum - any guesstimates on what it my do ?
Old Jan 7, 2021 | 01:18 PM
"Without seeing" it, I'll guess somewhere between scrap value and a million bucks.
Old Jan 7, 2021 | 01:22 PM
Bigmikey65's Avatar
I’m gonna go with the cost of a new swimming pool.
Old Jan 8, 2021 | 08:16 AM
Jeff Stout's Avatar
Steering wheel?
Im new to Olds stuff as I just bought a 68 Cutlass. Is the steering wheel pictured original to year of car. Asking because I look the style more then the 68 3 spoke wheel. Thanks
Old Jan 8, 2021 | 08:20 AM
  #31
That four spoke wheel was used on 1970-77 Oldsmobiles. Repros are available. Your 68 has a smaller diameter steering column, so for best appearances you really want to use the hub from a 1964-66 Chevy two spoke wheel. Repros of that are also available.
Old Jan 8, 2021 | 08:32 AM
  #32
BackInTheGame's Avatar
Joe, is this the one you are referring to? ThePartsPlace.
Old Jan 8, 2021 | 08:37 AM
  #33
Yes. It is the correct diameter for the 1968-older columns and accepts the four spoke wheel. There is also the hub used on the 1968 three spoke "wood" wheel, but it has the notch where the third spoke overlaps the center, leaving a gap when used with the four spoke wheel.
Old Jan 8, 2021 | 09:21 AM
  #34
Thanks, Joe.
Old Jan 8, 2021 | 09:36 AM
  #35
Jeff Stout's Avatar
Hib
Thank you. I will have a million questions later in the year when I start this project. Im building a clone Hurst my way and not an exact. It will have the Hurst touch but not 100% correct. This project will be a weekend driver. Pictures coming soon as it is a rust free AZ car. 350/350 a/c. Currently pearl white with light blue original interior
Old Jan 10, 2021 | 06:27 AM
  #36
Bfg's Avatar
Bfg
What’s the deal on the 68 442 Convertible?
Old Jan 10, 2021 | 11:50 AM
  #37
Ctls442's Avatar
Pm sent.
James Wallace
Jul 31, 2024 04:13 PM
teamwieland
Sep 11, 2018 12:21 PM
442crzy
May 13, 2017 02:01 PM
postw30man
Apr 25, 2016 11:53 AM
MN71W30
Aug 5, 2009 05:39 AM
