1970 Convertible Pump Bleeding
Old Apr 29, 2022 | 08:04 AM
WTHIRTY1's Avatar
Escape From The Ordinary
I did a search on bleeding the system with the trans fluid for the power top motor and cylinders, and the majority of responses indicated it's a "self-bleeding" system. The Fisher Body manual tells me otherwise. Is the best approach to fill the pump a little, cycle, and continue filling? I have new cylinders and hosing I'll be installing and the system is currently empty.
Old Apr 29, 2022 | 08:29 AM
Tedd Thompson's Avatar
The way I have always done it, and all hydrolic systems (cars and tractors) is fill it up with fluid, operate the system up and down, then refill the reservoir and repeat till you can't add any more fluid and there is no growing noise coming from the cylinder as a trapped air bubble. As far as I know, there isn't a bleeder on a car cylinder. Tedd
jpatfarrell
Nov 12, 2019 08:51 AM
timothypaul
Mar 7, 2018 12:16 PM
GoBigRed
Brakes/Hydraulic Systems
15
Oct 5, 2015 01:00 PM
servexcell
Sep 21, 2014 12:59 PM
mike623
Nov 8, 2012 09:17 PM
