1966 442 Frame interchangeability
Old May 26, 2019 | 04:39 PM
forstatd's Avatar
Can anyone help answer this for me.... will a 1966 Chevy El Camino frame (boxed) work as a replacement for a 1966 442 convertible without modification? Are they the same between the front frame horns... and the length?
Old May 26, 2019 | 05:00 PM
marxjunk's Avatar
yes and no..bolt in...no....after some slicing and dicing maybe..its longer behind the rear end...and according to research..the 442 is diff in the front to for the big radiator ( I cant confirm, but the interchange shows 442 has its own interchange number)
Old May 26, 2019 | 05:01 PM
lemoldsnut's Avatar
66 Frame is 66 only. Olds only. Convertible is the same as hardtop except it has the center sections boxed. If you take a hardtop frame and box the centers it is then the same. 67 has different spring mounts in the rear and 65 is very different in a few ways.
I have a few 66 hardtop frames if you decide to go that way.
Larry
Redmond, OR 97756
541-815-4363
lemoldsnut@aol.com
Old May 27, 2019 | 06:50 AM
Run to Rund's Avatar
66-7 also had boxing behind the rear wheels. True, 66 Olds is unique--wider for the crossflow radiator, rear spring perches for tangential coils at top (not pigtail like 67-up).
Old May 27, 2019 | 10:49 AM
66-3X2 442's Avatar
A little off topic but the 64 442 convertibles used El Camino frames.
GTMeach
Oct 19, 2018 06:00 AM
Collegecutlass
May 16, 2018 07:01 AM
T.TAKAPU
May 23, 2013 06:56 PM
trez
Mar 2, 2013 10:00 AM
330oldsmobile
Mar 19, 2012 06:18 PM
