Is the frame off a 4dr lemans interchangeable with my 1966 convertible?
Old Apr 12, 2013 | 03:07 PM
T.TAKAPU's Avatar
Hi, I wanted to know if a 1965 4dr lemans frame will interchange under my 1966 convertible cutlass? I will box it out myself. Jus wondering about the body mounts and the front horns. Let me know what u think. Thanks
Old Apr 12, 2013 | 05:59 PM
66400's Avatar
Body mounts are ok but 66 Cutlass frame horns are spaced wider apart.
Henry
Old Apr 12, 2013 | 07:32 PM
Rickman48's Avatar
I believe the wheelbase is different, 2dr to 4dr, and you'd loose a lot of strength, as the vert frame is partially boxed.
Old Apr 12, 2013 | 07:37 PM
I believe an "A" body is an "A" as far as the front horns go. I think there is a difference in the length of the frame, so I don't know if the mounts are in the same place. I believe will have to box the frame.
Old Apr 12, 2013 | 08:36 PM
66400's Avatar
GM A body for 64-67 2dr 4dr wheelbase is the same. Except Vistas and SportWagons.Henry
Old Apr 12, 2013 | 08:43 PM
66400's Avatar
66 and 67 Cutlass is the exception to the rule for 64-67 GM A body.The front frame horns are spread apart about 6 inches wider than the other 64-67 A bodies. Wheelbases are the same on 2dr and 4dr A body cars for 64-67. 115"Henry
Old Apr 23, 2013 | 11:09 AM
T.TAKAPU's Avatar
Thanks guys. I appreciate the help. It seems like jus finding a 66 or 67 cutlass frame will be the best. Thanks much
Old Apr 23, 2013 | 05:53 PM
Run to Rund's Avatar
Where are you?
Old Apr 24, 2013 | 03:11 PM
T.TAKAPU's Avatar
Sf bay area
Old May 23, 2013 | 03:23 PM
T.TAKAPU's Avatar
I just found a 1966 Oldsmobile ninety eight convertible frame. Will this work for my 1966 cutlass?
Old May 23, 2013 | 03:32 PM
No.
I have a hardtop frame for a 66 Cutlass, in Las Vegas, but you would have to add the boxing braces from your frame.
Old May 23, 2013 | 06:43 PM
T.TAKAPU's Avatar
How much you asking for the frame?
Old May 23, 2013 | 06:53 PM
redoldsman's Avatar
Proud Viet Nam Veteran
You are going to have to have a convertible frame since it is boxed to add strength for the convertible. A 98 frame would probably be about a foot too long. A 98 is a very large car and your cutlass is not. Just look at the wheelbase of these two cars.
Old May 23, 2013 | 06:56 PM
T.TAKAPU's Avatar
Thanks. @redoldsman
oldspackrat
Jul 20, 2022 07:34 AM
66cutlass
Mar 27, 2013 01:52 PM
sixty9olds
Jun 14, 2011 06:43 PM
DJMatthews
Dec 5, 2006 01:28 PM
