1966 4-Speed Console Mounting..
Old July 30th, 2021, 05:37 AM
forstatd's Avatar
Need a little help with a question. On a factory installed 4-speed console, were the mounting brackets welded to the floor or were they screwed down? When I bought my car in 1971 the console brackets were sheet metal screwed to the floor. Having just replaced the floor pan in my 66' I want to do it the right way. Thanks in advance!
~Dave...
forstatd is offline
Old July 30th, 2021, 05:46 AM
MI68442W30's Avatar
Dave , yes, they were welded. the same console and brackets as my 68 . I am not too far from you north of GR if you need some help?,did you convert your car to a 4 speed or was it a 4 speed originally?
MI68442W30 is offline
Old July 30th, 2021, 06:01 AM
forstatd's Avatar
Originally a 4-speed, but console was probably added before I purchased it in 1971. Console brackets were all screwed down. I do not see any old weld marks on the hump to indicate factory installed.
Thanks for the info!
forstatd is offline
Old July 30th, 2021, 06:22 AM
MI68442W30's Avatar
I forgot to mention that the front bracket was screwed to the floor as it would interfere with removal of the heater box,but the other 3 are welded.but you don't really need a console then if it didn't come with one and you should probably sell it to me ,I need one for my car yet.
Old July 30th, 2021, 06:27 AM
35tac's Avatar
Factory 4-speed.
My 66 Cutlass vert is factory 4-spead. Brackets were welded. I would upload a picture but for some reason It just doesn't work. Nice project. Have seen your car several times at Lansing. My favorite color.
Wayne
35tac is offline
green1972
July 2nd, 2020 07:14 AM
flyinmy172
October 25th, 2018 12:30 PM
Bfg
December 17th, 2017 12:33 PM
antweave
August 6th, 2013 09:30 AM
spate51
March 7th, 2012 11:14 AM
Quick Reply: 1966 4-Speed Console Mounting..
