A/C compressor not getting power
Old Jun 27, 2025 | 08:32 PM
Bigboy254's Avatar
Tried putting freon in my delta 88 2 door system but to no avail it wouldn't take. So I took a wire and jumped the compressor and now I have power. I take the wire off no power to the compressor. Can anybody help me with this. Is it minor or major.
Old Jun 27, 2025 | 08:51 PM
Charlie Jones's Avatar
Phantom Phixer
What year is this Delta 88 ?
Old Jun 27, 2025 | 09:38 PM
Bigboy254's Avatar
1985 delta 88 2 door royale brougham
Old Jun 28, 2025 | 12:06 AM
The 1985 cars use a clutch cycling orifice tube (CCOT) A/C system. There is a pressure switch in the system that interrupts power to the compressor clutch if freon pressure is too low. If adding freon doesn't fix the problem, that switch may be bad.
Old Jun 28, 2025 | 01:08 AM
Bigboy254's Avatar
where is this pressure switch located
Old Jun 28, 2025 | 06:59 AM
Old Jun 28, 2025 | 07:01 AM
Bigboy254's Avatar
Should I go ahead and change out the orfice tube. I really appreciate your time and effort.
Old Jun 28, 2025 | 07:12 AM
Without knowing the status of your A/C system, that is impossible to answer. Obviously you need to evacuate the freon before you can do that. Has the compressor been replaced recently? I would start by throwing a set of gauges on the system and seeing exactly what pressure you have. Also, disconnect the plug from the switch and jumper across the two terminals in the connector. Now see if the compressor clutch engages. If so, either you are low on freon or the pressure switch is bad.
Old Jun 28, 2025 | 04:20 PM
Bigboy254's Avatar
did everything you listed above new pressure switch install still nothing. Jumped the compressor from battery. No power at connector at low power switch. No the compressor hasn't been switched. Was working fine when I bought the car a couple of years ago. Blew ice cold.
Old Jun 29, 2025 | 12:26 AM
At this point, get a test light or voltmeter and trace the circuit until you find where the power stops.
Old Jun 29, 2025 | 09:10 AM
Phantom Phixer
This book may be very helpful.
1985 Oldsmobile Electrical Troubleshooting Man Cutlass Supreme Delta 88 Toronado | eBay
Do you have a set of gauges to measure the high and low side pressure in the system?
If so, what do they read with the compressor off? And on?
Old Jul 2, 2025 | 04:31 PM
Bigboy254's Avatar
went ahead and sent it to the ac shop. They found a leak at the low pressure switch. Also the guy told me that the computer is gone out. Therefore power isn't getting to the low pressure switch. What does all of this mean?
Old Jul 3, 2025 | 02:06 AM
Whenever someone says "the computer has gone out", it pegs my BS meter. The computer is nearly never the cause of a problem. It is far more likely that one of the electromechanical parts (relay, sensor, etc) has gone bad, or worse, that it was simply dirty/corroded connections. Of course replacing the computer requires disconnecting and reconnecting the electrical connectors. This wipes away the corrosion, everything works again, so obviously it had to have been the computer that needed to be replaced. Of course, simply disconnecting and reconnecting the original computer would have accomplished the same thing.
First question is, do you have the Temptronic/Comfortron electronic A/C or the regular manual A/C? The Control head on the Temptronic system will have temperature markings on the lower slider (65, 70, 75, etc). The manual A/C just says HOT and COLD. Is the shop talking about the engine control computer or the Temptronic programmer? The Temptronic system does have a lot of failure modes.
If we are talking about the manual A/C, the only connection from the computer to the A/C compressor is a single wire that controls a relay on the compressor clutch, and the only purpose of that connection is to temporarily cut power to the clutch at wide open throttle to provide a tiny bit more engine power for passing. Note the relay in the diagram.
https://cimg4.ibsrv.net/gimg/classic...e80bf6df63.png
Disconnect the relay and check for power at the green wire to the relay (terminal B). If there is power, jumper from B to E. Do you get power at the compressor clutch plug? Does the compressor turn on? Note that the pressure switch is in the ground side of the circuit, not the power side, so you might need to also jumper across that plug if the pressure is still low.
ART T
Feb 9, 2024 07:11 AM
Eddie Hansen
Feb 21, 2022 08:40 PM
tds
Jul 5, 2021 07:16 AM
Ger
May 7, 2019 03:00 PM
ls2gto
Aug 31, 2017 05:56 PM
