1978 Delta 88 a/c compressor wiring
Old Aug 31, 2017 | 03:00 PM
ls2gto's Avatar
Hello all - So I go to change the a/c compressor on my '78 88 and there is a brown wire that feeds into the back of the compressor. This wire comes off of one of the two wires on the front of the compressor that are used to operate the a/c clutch. What is the purpose of the brown wire that goes into the back of the a/c compressor? TIA
Old Aug 31, 2017 | 05:53 PM
Sugar Bear's Avatar
If it goes to a round switch/plug in the back of the compressor it is the high pressure cutout switch. The switch opens interrupting the ground circuit to the compressor clutch coil shutting off the compressor if the pressure gets too high.
Old Aug 31, 2017 | 05:56 PM
ls2gto's Avatar
awspeich
May 30, 2017 09:11 AM
Holiday350
Apr 18, 2013 10:17 AM
Joepapworth
Oct 30, 2007 04:51 AM
dcoymb
Dec 6, 2006 09:31 PM
