where to connect this starter wire?
Old Jul 16, 2022 | 12:56 PM
ben442's Avatar
68 442,
Just finishing my header install and noticed this starter wire broken. It was connected to the R terminal on the starter and I think it broke off at the wire ganged with the purple wire in photo.
Does this sound right?
Old Jul 16, 2022 | 01:33 PM
PatL's Avatar
on an all stock car, it goes from the starter solenoid to the coil. It is the wire that bypasses the resister wire for the points when you are starting the car. Gives the points full voltage.
Old Jul 16, 2022 | 01:39 PM
ben442's Avatar
I have hei set up does that change anything?
Old Jul 16, 2022 | 02:01 PM
ben442's Avatar
I found a post that says the yellow wire is not required to be connected to the R terminal with hei.
Should I just delete it?
Old Jul 16, 2022 | 02:12 PM
PatL's Avatar
You should have connected full power to the HEII, so would of bypassed the resister wire already. So yes not needed. I would just cut or wrap the lerminal end in case you ever go back to points.
Old Jul 16, 2022 | 02:15 PM
ben442's Avatar
Great, thanks for the help. appreciated.
Ben
Old Jul 16, 2022 | 02:27 PM
The reason it was cut is because when spliced to the purple wire and still connected to the coil+ terminal, whenever the key was in the on position it would cause the starter to engage feeding voltage to the S terminal on the starter solenoid from the coil.
Old Jul 17, 2022 | 02:24 PM
ben442's Avatar
here is where I'm at.
Left the wire connected to S terminal and removed the wire from the R terminal.
Put the car down on the ground and started it to move out of the garage.
Let it idle to bake on the header high heat paint.
Shut it off after about 20 minutes and let cool.
Went out to run it for another 20 minutes and I have a no start problem.
Starter doesn't seem to be doing anything when I turn the key.
Battery is good.
The starter is not stuck in an engaged position.
??? I think my starter just died.
Old Jul 17, 2022 | 02:44 PM
PatL's Avatar
first the simple stuff, check that your purple wire is still attached to the S terminal. Also so you are saying no noise, clicking etc coming from your starter?
Old Jul 17, 2022 | 03:07 PM
ben442's Avatar
I will check that the wires are connected properly when I get back to this tomorrow eve.
Yes no clicking, no sound from starter when engaging the ignition.
Old Jul 23, 2022 | 08:06 AM
ben442's Avatar
Update: got it fixed, bad connection at the S terminal on the starter. Note to Self- fix frayed wire connector before reinstalling.
HarrySlother
Oct 3, 2021 07:38 AM
Gunmars
Aug 4, 2015 05:00 PM
tcarroll
Sep 14, 2014 09:03 AM
Niko
Apr 9, 2014 08:56 PM
mcutlass1969
Jun 23, 2007 08:49 PM
