1987 Custom Cruiser HVAC question
Old November 17th, 2018, 12:20 PM
ruf455's Avatar
Anyone here familiar with the '87 fullsize cars? I am interested in figuring out how to get my temperature control to function as it should. All under hood systems are new (heat and a/c). The a/c is snow ***** cold...aaaannnd so is the heat. I can not warm the air for full heat or a/c temp regulation. Any ideas? I have the shop manual on order and was wondering if anyone was familiar with what may be THE issue. And yes, the system is getting the proper vacuum signal from the engine.
ruf455 is offline
Old November 17th, 2018, 01:45 PM
Is it standard A/C with the cable controlled temp blend door or Tempmatic with the automatic temp control?
joe_padavano is offline
Old November 18th, 2018, 04:20 AM
Are your radiator and heater core in good condition? If you're low on coolant or if your heater core is plugged that could cause a no-heat situation.
Olds64 is offline
Griswold '90
March 2nd, 2020 11:43 AM
Olds83Cutlass
December 19th, 2016 07:46 AM
Dream Whip
August 9th, 2016 02:59 PM
Armando S Nortez
August 23rd, 2013 04:37 PM
1BOSS83
April 4th, 2013 10:43 AM
Quick Reply: 1987 Custom Cruiser HVAC question
