1987 Custom Cruiser HVAC question
Old Nov 17, 2018 | 12:20 PM
ruf455's Avatar
Anyone here familiar with the '87 fullsize cars? I am interested in figuring out how to get my temperature control to function as it should. All under hood systems are new (heat and a/c). The a/c is snow ***** cold...aaaannnd so is the heat. I can not warm the air for full heat or a/c temp regulation. Any ideas? I have the shop manual on order and was wondering if anyone was familiar with what may be THE issue. And yes, the system is getting the proper vacuum signal from the engine.
Old Nov 17, 2018 | 01:45 PM
Is it standard A/C with the cable controlled temp blend door or Tempmatic with the automatic temp control?
Old Nov 18, 2018 | 04:20 AM
Are your radiator and heater core in good condition? If you're low on coolant or if your heater core is plugged that could cause a no-heat situation.
Griswold '90
Mar 2, 2020 11:43 AM
Olds83Cutlass
Dec 19, 2016 07:46 AM
Dream Whip
Aug 9, 2016 02:59 PM
Armando S Nortez
Aug 23, 2013 04:37 PM
1BOSS83
Apr 4, 2013 10:43 AM
