No heat!
Old Apr 4, 2013 | 07:29 AM
1BOSS83's Avatar
No heat!
83 H/O, when the car gets to temp and you turn on the heater and blower it blows outside air. No heat, is this mechanical or vaccume?
Thanks,
Adam PA
Old Apr 4, 2013 | 10:37 AM
frankr442's Avatar
A cable runs from the control to a lever on top of the heater case. This controls the mixing door. That plastic lever broke on my 83 Regal. Possibly a plugged heater core? There's also a vacuum operated valve on the intake manifold. Feel for heat on the hose from that valve to the core.
Old Apr 4, 2013 | 10:43 AM
Thanks,
Adam PA
Heater blend door behind the glovebox. Pull out the glove box insert to see it. Then read these threads. This is a common problem on the 1978-1988 A/G-body and 1977-1990 RWD B/C-body cars.
https://classicoldsmobile.com/forums...2-no-heat.html
https://classicoldsmobile.com/forums...lows-cold.html
https://classicoldsmobile.com/forums...questions.html
Dream Whip
Aug 9, 2016 02:59 PM
smcurro
Paint
Jan 29, 2012 02:31 PM
bjtstarfire
Nov 13, 2008 02:04 PM
<sammy>
Sep 1, 2006 05:04 AM
Bens71442
Jan 3, 2006 03:33 PM
