No heat!
A cable runs from the control to a lever on top of the heater case. This controls the mixing door. That plastic lever broke on my 83 Regal. Possibly a plugged heater core? There's also a vacuum operated valve on the intake manifold. Feel for heat on the hose from that valve to the core.
https://classicoldsmobile.com/forums...2-no-heat.html
https://classicoldsmobile.com/forums...lows-cold.html
https://classicoldsmobile.com/forums...questions.html
