Help with electrical issue
Old Dec 24, 2017 | 01:19 PM
tdmvlm's Avatar
I have a 1973 Cutlass S automatic that I am working on. I have removed the center console and the front seats. Now the car will not crank over. I see the passenger seat has a electrical connection on it which is unhooked because I removed seats also the electrical connections on the console is unhooked. Would any of these keep the car from turning over?
Old Dec 24, 2017 | 01:33 PM
Gary M's Avatar
Is the shifter in the console? If so the wires may be part of the circuit that includes the neutral safety switch. Just a thought.
Cincinnati Rick's Avatar
You probably disconnected the neutral safety switch harness. Put a jumper across the connector and it should crank
Old Dec 24, 2017 | 01:41 PM
Are there 2 purple wires terminated on a single connector that were disconnected?
Old Dec 24, 2017 | 01:56 PM
tdmvlm's Avatar
Yes shifter is in console. I thought it might be something like that. Would you happen to know what the electrical connection on the passenger seat is for?
Old Dec 24, 2017 | 02:03 PM
Gary M's Avatar
Seat belt warning. If no one is sitting there the warning would not sound if belt wasn't buckled? Or air bag circuit?
Old Dec 25, 2017 | 06:33 AM
The neutral safety switch on a 1973 Olds is at the base of the column. There is no starter circuit wiring in the console. The backdrive linkage from the trans to the steering column operates this switch. If you have disconnected the backdrive linkage, you have disabled the NSS. Look at the base of the steering column under the dash. Remove the two wire connector with purple wires from the switch and jumper across them. If the car starts, you've found the problem.
Old Dec 25, 2017 | 06:53 AM
Gary M's Avatar
If the console is out, is it possible the shifter is not fully in park?
Old Dec 29, 2017 | 02:00 PM
tdmvlm's Avatar
Thanks everyone for your help. I have figured out the problem. The person before me had some gauges in it and I removed them when removing the console. One of the gauges was an amp gauge the he had spliced into the main power supply wire. With the gauge being disconnected I had no power to anything. I hooked gauge back up and everything is OK. Again thanks
everyone.
Old Dec 29, 2017 | 02:05 PM
everyone.
Glad you got it figured out, but the message there is that when asking a question, we don't know about any non-stock mods done to the car unless you tell us about them.
Old Dec 29, 2017 | 03:48 PM
tdmvlm's Avatar
You are right. I should have paid more attention to what I had done before I asked for help. Again thanks for your time in trying to help me. But at least I figured it out. Joe I did learn some good information from the replies that I could use in the future.
Old Dec 29, 2017 | 04:01 PM
You don't want the cars electrical system flowing through the ammeter. I'd wire it like this:
Old Dec 29, 2017 | 09:19 PM
gs72's Avatar
72Cutlass S
Or just replace the ammeter with a good volt meter.
Old Dec 29, 2017 | 09:24 PM
tdmvlm's Avatar
That's what I am going to do. Voltmeter is safer than amp gauge. I know amp gauge is better for troubleshooting purposes, but would rather be safe with my pride and joy.
Ezln1688
Oct 25, 2015 07:04 AM
jpaulwhite
Aug 21, 2010 06:08 PM
dhartley72
Mar 15, 2010 08:12 AM
blueolds68
Feb 9, 2010 06:55 AM
4speedBench
Aug 13, 2009 04:36 AM
