Electrical issue need help
Old Oct 15, 2015 | 07:15 PM
Ezln1688's Avatar
I have a 64 98 that was starting/running just fine. My battery died on me(I must of left something on over night. When me and a buddy where jump starting it turned on. My buddy was removing the jumpers and one of the terminals came off with it. Car turned off and haven't been able to start it again! Car just cranks over but it's not firing up
Old Oct 16, 2015 | 03:00 AM
1970cs's Avatar
Lansing built
I am assuming that the battery terminal -/+ came off the battery?
I would start with the basics.
Does it have spark? pull a plug out and ground it, unless you have a tester
Is it getting fuel? pull air cleaner, look down the carb. and stoke the throttle lever.
Pat
Old Oct 16, 2015 | 05:36 AM
Original points, or have you converted it to an electronic ignition?
Old Oct 16, 2015 | 12:15 PM
Ezln1688's Avatar
It looks I have no spark, so I tried a different coil but I still have nothing!
Yes I converted it to electronic ignition a few months back?
Old Oct 16, 2015 | 12:24 PM
Perhaps a transient voltage spike while jump-starting, or when the cable came off the battery while the engine was running, damaged the electronic module.
Old Oct 16, 2015 | 01:14 PM
Ezln1688's Avatar
How would I diagnose that issue?
Old Oct 16, 2015 | 01:32 PM
Well, what kind of electronic ignition do you have?
Have you checked for the correct voltage into the distributor?
Have you checked the condition of the cap and rotor?
Old Oct 16, 2015 | 02:02 PM
stellar's Avatar
stellar
If the alternator is working, removing the battery cable when running will cause a voltage surge (spike). The high voltage can damage electronic components and modules. I suspect the ign module is now done. It is a good idea to have the blower motor on high whenever jumping to help absorb any surge or transient spikes.
Old Oct 16, 2015 | 02:52 PM
Ezln1688's Avatar
I can't recall what kind I bought but the cap and rotor, spark plugs/wires are all pretty much new. Everything was in working order when I got the car, just wanted to fresh it up a lil
I believe my alternater is still working!
Old Oct 16, 2015 | 03:53 PM
I would make sure I have power on the coil+ post with the key in the start and run positions. If you have power there its probably the electronic ignition that failed inside the distributor.
Old Oct 16, 2015 | 04:02 PM
Octania's Avatar
If only there were a mechanical means of triggering the coil, that does not rely on electronics!
Old Oct 16, 2015 | 04:31 PM
Indeed. One that was immune to power surges and random failures.
Ah, well... Dreams...
Old Oct 16, 2015 | 05:26 PM
1970cs's Avatar
Lansing built
Now that I have time, I agree with the others, module! What do you have Pertronix or HEI delco distributor?
Pat
Old Oct 16, 2015 | 05:33 PM
Ezln1688's Avatar
Haha yeah guys that would be cool!!!
I'm not sure I just have the original distributor and did the electronic conversion to it.
Old Oct 16, 2015 | 05:41 PM
We are being facetious.
Old Oct 17, 2015 | 04:36 AM
1970cs's Avatar
Lansing built
Here is the trouble shooting for Petronix set ups.
http://www.pertronix.com/support/tips/#a1
Pat
Old Oct 17, 2015 | 05:11 AM
m371961's Avatar
Amazing concept Eric. A ignition system one can visually see working or not!
Old Oct 24, 2015 | 08:16 PM
Ezln1688's Avatar
Hey guys I finally got time to check out the situation with the olds, infact it was the ignition module as you guys suggested! So it's back on the road thank you guys! got to say my fav part of owning this olds is the community behind it always willing to help!!��
Old Oct 25, 2015 | 03:09 AM
Glad we could help!
Old Oct 25, 2015 | 07:04 AM
Well done
ChefDeadpool
Dec 26, 2010 07:55 AM
jpaulwhite
Aug 21, 2010 06:08 PM
dhartley72
Mar 15, 2010 08:12 AM
blueolds68
Feb 9, 2010 06:55 AM
4speedBench
Aug 13, 2009 04:36 AM
