I need a new alternator
Old Aug 30, 2016 | 01:42 AM
Jandk's Avatar
Do any of you knowledgeable Oldsmobile experts know which alternator My 1964 Oldsmobile 98 have been fitted with??
It is the original ext regulated alternator. I have looked for stamped numbers and so, but cant find anything thats tells me what alternator it is. I have looked in the service manual, but cant anything I understand.
I guess RockAuto could supplie a new one together with my new purchase.
Any help is much appriciated.... Thanks
Old Aug 30, 2016 | 06:39 AM
oddball's Avatar
It should be a typical GM 10DN alternator. Reman units normally have smudged, removed, or no stampings like the original units.
Rock Auto has a selection of reman replacements.
Now, if you want a numbers-matching replacement for originality, place a parts wanted ad and see what shows up. I'm sure someone on here has an original application list for your car.
Old Aug 30, 2016 | 11:58 AM
Jandk's Avatar
Numbers matching wont be neccessary.
I will have a look at Rock Auto for 10DN unit.
Thank you Oddball
Old Aug 30, 2016 | 12:10 PM
Just out of curiosity, what numbers "match" on an alternator. I'm sure you mean "correct" and proper date code, but unlike VIN derivative stamps that prove originality of a block or trans case, there's no such thing as a "numbers matching" alternator. The difference is that there will be thousands of potentially correct alternators, but only one original numbers matching block.
Old Aug 30, 2016 | 12:21 PM
Jandk's Avatar
If I should be tempted to go for a more than 55Amp alternator, and still a DN10 as you say is the correct one, which cars would have like a 60-70Amp alternator fitted??
Old Aug 30, 2016 | 03:01 PM
The 1972 Olds Ninety Eights used a 10DN style (external regulator) alternator rated at 63 amps. It will bolt in place of your current one. RockAuto sells version with a one-groove and a two-groove pulley.
Old Aug 31, 2016 | 12:01 AM
Jandk's Avatar
Thank you sir... Very very nice. I did try searching RockAuto, I didnt have any luck. I do not think the RockAuto parts search function works very well.
Old Aug 31, 2016 | 06:29 AM
oddball's Avatar
s/match/correct/
442mark
Sep 30, 2017 01:06 PM
mdfedewa
Mar 28, 2012 01:30 PM
yeahbuddy
Mar 6, 2012 04:22 AM
dan2286
Sep 20, 2008 08:38 AM
gearheads78
Sep 3, 2008 11:12 AM
