wiring harness
Old Aug 30, 2016 | 05:32 PM
ankerclanker's Avatar
wiring harness
Ok guys, i'm pretty sure this has been asked before, but here goes anyhoo. I am looking for a complete plug and play wiring harness for my 65 f85, have looked at summit, opgi, jegs and m&h. who makes a harness that is a good replacement?
thanks
ted
Old Aug 31, 2016 | 06:37 AM
Have you tried American Auto Wire direct?
Old Aug 31, 2016 | 03:35 PM
franks71cutlass's Avatar
Ted, I highly recommend M&H!! I first researched what was out there, went to OPGI to see what harnesses they had for my 71 Cutlass Supreme! Found out they used M&H! So , went directly to them here in SoCal! Received a better price, not having a middleman! They build everything from GM specifications, right down to color matched wires and connections!
I replaced everything under hood, Engine Harness, A/C and Front End Harness! Plus they modified my engine Harness for HEI and Electric Choke! They have a small fee for those Modifications, I think less than $20 bucks each! It's over 3 years ago, so I would have to check my records! Everything plugged right in like factory, all the correct length of wire! No, slop what so ever!! Here's there info:
M&H Electrical Fabricators
13537 Alondra Blvd.
Santa Fe Springs, CA. 90670
Email sparky@wiringharness.com
Phone 562-926-9552 Ext. 209
Fax 562-926-9572
If you want the best factory correct replacement wiring for Most GM cars, theses are the guys! I wouldn't recommend anyone else! It's plug and Play, and can't tell from original, except there M&H Log on the end of the harness, in place of the GM code!
Going on 3 years not ever a issue with my replacement Harness!!
frank
PS, You can view some pictures in my gallery of the wiring if you like to see it installed!?
Old Aug 31, 2016 | 06:48 PM
No I haven't, but I will now. thanks for the info
ted
68Tom
Nov 5, 2008 05:30 AM
mugzilla
Oct 22, 2008 12:06 AM
Olds64
Oct 3, 2007 05:34 AM
elmo
Sep 23, 2007 02:49 PM
stuart
Aug 14, 2004 02:24 PM
