Washer fluid won't stop spraying
I have a 76 Cutlass Supreme Coupe. I was cleaning the engine, had all major components covered, and when I was done, I started the engine and the windshield washer fluid would not stop spraying until I turned the ignition off. There are two wire harnesses to the motor, one for the wipers and one for the fluid. When I unplug the washer fluid plug, all is good. Did I potentially short it out or is the motor bad. Thanks in advance.
cfair
Brakes/Hydraulic Systems
June 8th, 2009 12:37 AM
