Washer fluid won't stop spraying
Old Jul 3, 2013 | 03:46 PM
plonka's Avatar
I have a 76 Cutlass Supreme Coupe. I was cleaning the engine, had all major components covered, and when I was done, I started the engine and the windshield washer fluid would not stop spraying until I turned the ignition off. There are two wire harnesses to the motor, one for the wipers and one for the fluid. When I unplug the washer fluid plug, all is good. Did I potentially short it out or is the motor bad. Thanks in advance.
Old Jul 3, 2013 | 03:50 PM
Redog's Avatar
It's possible.
Let it "dry out" for a day. Unplug the plug and let it sit. A day at the most. This is the cheapest thing so try it first
Old Jul 3, 2013 | 10:16 PM
plonka's Avatar
Thanks Redog, that did the trick.
Old Jul 4, 2013 | 05:26 PM
stellar's Avatar
You might want to put some dielectric grease in the plug to help protect it for the next time you clean it. Won't hurt.
steedaq
Apr 8, 2015 07:57 PM
Tedd Thompson
Paint
Oct 1, 2012 03:24 PM
navvet
Nov 16, 2011 03:27 AM
silverriff
Nov 19, 2009 04:49 PM
cfair
Brakes/Hydraulic Systems
Jun 8, 2009 12:37 AM
