Power Antennae
Power Antennae
Was a power antennae an option on a 66 Cutlass convertible? If so how easy is it to get one or does anyone out there make a decent one? I've seen some garbage out there that just doesn't impress me. Looking for opinions and any help.
George
George
![Wink](https://classicoldsmobile.com/forums/images/smilies/wink.gif)
It mounted in the right rear quarter. You need to weld up the hole in the front fender to install one. Correct ones cost a fortune.
Tim
George,
I was in the same position as you with getting a not so good one off of eBay. It was almost impossible to find a complete power antenna. Instead of trying to get a complete power antenna I started too piecemeal it. I spent many hours researching the part numbers for each component. I found the following parts
66/67 Power antenna switch with plate used $30.00
66/67 Power antenna mounting bracket used $30.00
65-69 Power antenna nut new Fusick $25.00
66/67 Power antenna chrome spacer couldn’t’ find
Power antenna wiring new Fusick $60.00
65 Power antenna assy new NOS $425.00 with coaxial wiring
During the search for the final part (chrome spacer) I saw a Craigslist listing that had the completed Power Antenna with every single part for $475.00 plus shipping.
RAMBOW
November 11th, 2011 09:27 AM
