Power Antennae
Old Mar 2, 2014 | 12:36 PM
TripDeuces's Avatar
Power Antennae
Was a power antennae an option on a 66 Cutlass convertible? If so how easy is it to get one or does anyone out there make a decent one? I've seen some garbage out there that just doesn't impress me. Looking for opinions and any help.
George
Old Mar 2, 2014 | 03:28 PM
George
Yes, but there was only a single power antenna.
It mounted in the right rear quarter. You need to weld up the hole in the front fender to install one. Correct ones cost a fortune.
Old Mar 2, 2014 | 07:06 PM
TripDeuces's Avatar
I remember seeing these now. Thanks Joe. I did see one on Ebay for $375, ouch. I might have to go aftermarket although I'm not a fan of them.
Old Mar 3, 2014 | 09:04 AM
tmaleck's Avatar
When I did the Vintage Air conversion on my 67, once the original evaporator was out, there was plenty of roof for a power antenna in the front antenna location. I doubt you want to do that just to add an antenna. I have tried a couple of brands over the years and have settled on Hirschman. The rest failed so quickly they never made it out of warranty.
Tim
Old Mar 16, 2014 | 06:55 AM
66olds4dr's Avatar
George,
I was in the same position as you with getting a not so good one off of eBay. It was almost impossible to find a complete power antenna. Instead of trying to get a complete power antenna I started too piecemeal it. I spent many hours researching the part numbers for each component. I found the following parts
66/67 Power antenna switch with plate used $30.00
66/67 Power antenna mounting bracket used $30.00
65-69 Power antenna nut new Fusick $25.00
66/67 Power antenna chrome spacer couldn’t’ find
Power antenna wiring new Fusick $60.00
65 Power antenna assy new NOS $425.00 with coaxial wiring
During the search for the final part (chrome spacer) I saw a Craigslist listing that had the completed Power Antenna with every single part for $475.00 plus shipping.
tommy23t
Jul 31, 2014 06:02 PM
Tom442
Apr 8, 2012 07:09 AM
RAMBOW
Nov 11, 2011 09:27 AM
1001coins
Aug 29, 2010 02:25 PM
1FSTLS1
May 30, 2008 07:42 AM
