Map Light Power Source
On a 72 vert, where does the map light power lead plug into behind/underneath the dash? The manuals seem to indicate it plugs into one of the aux. slots in the fuse block - is this correct?
Is this the mirror light or a dashboard light?
The dashboard lights generally plug into the orange dome light / cigarette lighter lines, but the mirror light plugs into the ignition switch circuit.
The maplight power lead will plug directly into the fuse block and into a contact that is controlled by the ignition switch. It's only "hot" when the key is in the ACC or ON position. Also the wiring is comprised of 2 pieces. If you take a look at my thread, you will see pictures of this since I received help on this same topic a few weeks ago.
https://classicoldsmobile.com/forums...n-project.html
Brian
Brian
branemi
July 20th, 2007 09:46 PM
