Instrument lights stuck on
Old May 25, 2010 | 06:32 PM
dhoff's Avatar
1971 Cutlass Supreme: Anyone had a problem with the instrument lights staying on even with the headlight switch off? I looked the wiring harness over but didn't see any obvious short. I did put a tilt steering column from a 72 monte Carlo in it but the plug seemed to match up. I'm thinking maybe a headlight switch? DHoff
Old May 26, 2010 | 04:10 AM
dhoff's Avatar
Any ideas? Change switch or wire harness or both?
Old May 26, 2010 | 05:18 AM
Lady72nRob71's Avatar
Pull the 4A fuse marked INST LPS.
If they go off, I would suspect light switch. If they stay on, you have a short somewhere further down the line, like in the console or around the radio (if wiring has been hacked).
When they are stuck on, do they still dim with the ****??
If so, that points to the light switch again....
Old May 27, 2010 | 06:18 PM
dhoff's Avatar
Found Problem
I found a gray wire( dash lights) connected to an orange hot wire, in an area that I have never worked on, must have been when the previous owner took the radio out.
Old May 28, 2010 | 05:19 AM
Sounds like the problem to me!
I hate "previous owner wiring hacks"...
deltaroads
Oct 26, 2015 04:08 PM
Teamcamber
Dec 5, 2014 09:18 AM
arod40
Jun 15, 2013 11:16 PM
68RocketAction
Jun 7, 2013 09:21 PM
Dshelvy
Mar 19, 2012 08:12 PM
