Instrument lights
Old Aug 18, 2023 | 02:20 PM
george@BWR's Avatar
Instrument lights
I have a 1972 olds cutlass supreme and the instrument lights went out while I was driving. All other lights are working and when I checked the fuse it was blown. Put in a new fuse and it blew also. Any ideas?
Old Aug 18, 2023 | 02:56 PM
You obviously have a short. You need to find it. There isn't any magic here, just brute force tracing of every wire on that circuit (it's the grey wires in the dash harness). I assume the fuse that is blowing is the 4A INST LPS fuse, correct? Have you added anything to the lighting circuit? The INST LPS fuse powers the gauge illumination bulbs in the three instrument clusters, the clock lamp, the heater lamp, ash tray lamp, and the headlight switch lamp.
Old Aug 18, 2023 | 03:19 PM
george@BWR's Avatar
It is the 4 amp INST LPS fuse. Nothing has been added to the circuit. Lights just went out while I was driving/
Old Aug 18, 2023 | 06:00 PM
Texas69's Avatar
Short
Pull the map light in the center of the dash and inspect. Something happened to mine and the wiring connections or switch melted, creating a short and jacked up the lights. It's been a few years and cannot remember the details, but such a situation would be easy to identify.
Old Aug 18, 2023 | 06:45 PM
george@BWR's Avatar
Thanks! I'll start there.
Old Aug 19, 2023 | 08:26 AM
george@BWR's Avatar
Does this plug look burned to you?
Old Aug 19, 2023 | 09:10 AM
Could be. Hard to tell in that photo, as the damage could also have been caused by someone trying to pry the connector apart with a screwdriver.
Old Aug 19, 2023 | 09:11 AM
If anything the picture looks really blurry. What color is the wire and it's location?
Old Aug 19, 2023 | 02:51 PM
george@BWR's Avatar
The wire is gray and it is behind the speedometer
350cuttyliteson
Apr 12, 2023 07:16 PM
BlueCalais79
Sep 7, 2021 04:41 AM
mmitton
Jul 22, 2018 01:11 PM
coppercutlass
Jul 30, 2011 02:36 PM
millwrightrice
Jul 13, 2007 11:51 AM
