runing lights dont work
ok guys this is weird first for me . so the other day i took the olds out to a local cruise night and on the way there my buddy says "hey how come you didnt have you ambers on "., i turned them on but they never came on. i turn my lights on and they come on but no rear lights my turn signals work my hazzards work but stay on the whole time they dont blink but they do cut in and out when i hit the brakes so all my lights work just no rear lights or front ambers when the switch is on. could it be a fuse or the switch. i figured if its a ground they wouldnt come on at all and same if it was a fuse i assume. i looked at all my connections checked my bulbs everything looks good any help is greatly appreciated . also they worked fine when i did my pre crusing season check
it was the fuse i got under there i didnt realize they run diffrent fuses for tail,park, and running lights im so used to working on new cars where its usually one fuse thanks for the help mdchanic
smkn600ctd
Dec 29, 2014 05:38 PM
