Instrument Basel
Old May 18, 2026 | 09:31 AM
NinetyEight67's Avatar
Instrument Basel
Has anyone removed a dash on a 67 Ninety Eight olds if so what all needs to be done, I need to remove my speedometer I’m thinking there’s a problem in the printed circuit board. Thanks
Old May 18, 2026 | 09:45 AM
I doubt it. Why do you think it's a problem with the circuit board? I wouldn't disassemble the dash without a Factory Service Manual and Chassis Service Manual. Check to see if they're available at Fusick:
https://www.fusickautomotiveproducts.com/
Old May 18, 2026 | 10:26 AM
Dash
I’ve check’d all fuses and also the back side of the fuse panel, I’ve check’d the plug going on to the circuit board and have power to on plug, I also put in a new headlight switch turn it all the way counter clockwise and still no instrument lights.
Old May 18, 2026 | 01:34 PM
Validate you have a ground connection to the dash instrument cluster (panel).
Old May 18, 2026 | 01:54 PM
Vintage chief
What the best way to do that?
Old May 18, 2026 | 02:12 PM
Review the dash IP ground locations in the 1967 Product Information Manual [PIM] (AKA Assembly Manual).
NOTE: Below are ground strap locations located in the 1969 PIM. Again - this is NOT from the 1967 PIM. I do not have the 1967 PIM. You "might" glean some information from this diagram (below). Again, this is NOT from the 1967 PIM.
Old May 18, 2026 | 02:33 PM
Unfortunately, despite using nearly the same instrument pods, the backside of a 1967 Olds full size dash is completely different than the backside of a 1969 Cutlass dash.
Old May 18, 2026 | 02:39 PM
Purchase a 1967 Product Information Manual (PIM) from Hairy Olds. You should have this essential manual in your library.
1967 A,B,C,E models Product Information Manuals
Bfg
Nov 22, 2023 04:56 AM
aljmann
Sep 22, 2020 07:58 PM
rctoyguy
Nov 27, 2014 02:00 PM
Blaine B.
21
Dec 18, 2012 10:02 PM
Bill Poston
Mar 10, 2009 10:06 AM
