Idiot light
Old Sep 19, 2025 | 04:48 AM
Bigzo's Avatar
Enzo
Idiot light
Generator light stays on when car shut off and key pulled , any suggestions ? The car is a 69 442.
Old Sep 19, 2025 | 06:33 AM
Sugar Bear's Avatar
Probably a bad diode in the alternator. Unplug the alternator if the light goes out the problem is in the alternator. Suggest getting yours rebuilt locally especially if it is original to the car.
Old Sep 19, 2025 | 09:07 AM
If it has a separate voltage regulator, it can be that also.
Old Sep 19, 2025 | 09:19 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Firewall mounted regulator is sticking. Turn the headlights on when the car is off. Can you hear the regulator disengage an the light goes out?
Old Sep 20, 2025 | 05:16 AM
A 1969 442 should have an open face 10SI with internal regulator.
To the OP: Is this the original alternator or a replacement?
Candyman68
Jun 26, 2024 01:35 PM
CRUZN 66
Dec 12, 2022 06:14 PM
BSiegPaint
Aug 30, 2021 01:46 PM
kevdog442
Feb 24, 2021 04:24 PM
dave marki
Jun 5, 2017 10:18 PM
