help ,neutral safety switch
Old Dec 11, 2011 | 04:38 PM
willj's Avatar
hi, would be happy with any input with this problem.i have tried 2 new nuetral saftey switches ,but when i run the shift threw the gears , they keep blowing fuse in the fuse panel, i notice the generater dash light is always on,it goes out to when fuse blows, i have to old switches when i pit them in ,the back up lights work fine , i have adjusted the new and old switch with the little rod you put in the hole when it is in the drive position ,like the manual says. how can something so simple ,be such a pain , maybe i should just put a toggle swich , hate to, any way thanks very much , will.
Old Dec 11, 2011 | 04:44 PM
Lady72nRob71's Avatar
What fuse blows? What year and model?
Old Dec 11, 2011 | 06:02 PM
willj's Avatar
sorry,for lack of info, car is 65 starfire. and the fuse in the fuse panel that blows, is the one marked transmision. thanks will.
Old Dec 11, 2011 | 08:49 PM
Rickman48's Avatar
Check the plug that goes into the trans for the 'switch-pitch' convertor - probably broke and shorting!
Old Dec 12, 2011 | 05:29 AM
willj's Avatar
all so if i jump the wire on the plug that goes into nuetral switch ,back up lights come on. thanks again will.
Old Dec 12, 2011 | 12:03 PM
willj's Avatar
more symptoms.
started car today,and when i went through gears, when i hit reverse , the generator light came on very dim.neutral it went out,drive it came on bright.also i did not put a new fuse in yet,at this time when i turn key on ,no light , if i put new fuse in , when i turn key on ,i have a light , and it will spark at the nuetral switch when i go into reverse, i don,t know ,it could be worded better, but still any ideas would be appreciated, thanks ,will.
Old Dec 12, 2011 | 12:32 PM
And the back-up lights come on normally?
This is strange...
Old Dec 12, 2011 | 02:01 PM
willj's Avatar
that is with a jumper wire , or if i put the old switch back in,then i can only start car in drive , i am getting mixed up my self now , thanks ,will.
Old Dec 12, 2011 | 02:30 PM
Both your neutral safety and your backup lights operate off that switch assy. The 2 purple are the neutral safety and I believe the lt grn and dk green/ wht wires are your backup lights. I would isolate the 2 circuits for now and concentrate on the purple wires to get your neutral safety system working first.
Then start working on the backup lights. do you have a wiring diagram.
click on this link:
Its the last 2 towards the bottom of the page.
http://www.oldcarmanualproject.com/t.../oldsindex.htm
Old Dec 14, 2011 | 08:28 AM
willj's Avatar
still no luck!
well i got the car to start in park and nuertal, now ,but when i go to shift by reverse ,i can see and hear a spark inside the nuetral switch, i don,t understand how this can be cause when i put jumper wire in the two green wires the back up lights come on, maybe a defective switch ,but 2 new bad switches in a row, from different stores,also when i put the old switch back in,backup lights work fine, just won,t start in park, took one of the old switches apart cleaned ,and can,t see any thing wrong, any sugestions. thanks will.
Old Dec 14, 2011 | 08:52 AM
Have you stuck an amp meter on the circuit. There are only 2 bulbs, so there should not be a tremendously hi load on it.
Old Dec 14, 2011 | 11:27 AM
W70442's Avatar
Isn't there a solenoid on the switch pitch? The solenoid or the wires going to it could be shorting to the frame/chassis.
Does the trans physically shift correctly into and out of all the gears?
The fact that the back up lights work with out blowing a fuse would seem to indicate that they aren't the problem.
Old Dec 14, 2011 | 12:14 PM
willj's Avatar
hi, i don,t have an amp meter, will have one soon , so i took fuse out of the fuse panel,that says trans on it.i hooked up volt meter to the plug for back up lights,the two green wires, and there was a 8 volt reading on the gauge, reversed wires and need went below 0, put fuse back in and the gauge went up to 100 . mean while generator light is on all the time as long as a good fuse is in that trans spot,and the transmission shifts perfect in and out of the gears,also the generator loight goes brighter when starting car, then goes back to just being on after you let go of key, i thank all for the input, will.
Old Dec 14, 2011 | 02:33 PM
All volt readings need to have the negative lead of your meter tied to ground. What your reading is back fed voltage thru a circuit. You are getting stray voltage through your gen light possibly do to a bad ground somewhere.
oldspackrat
Nov 17, 2014 06:31 AM
dhartley72
Jun 4, 2010 01:51 PM
70 ctls
Jan 28, 2009 03:20 PM
footbrake
Jun 12, 2006 06:10 PM
oldsnut7098
Aug 10, 2003 10:06 PM
