neutral safety switch or linkage problem???? Help!!
i just brought another 72 cutlass today.....my problem is i have to crank it up in Reverse and then i can put it in park,drive and everything else.... car drives perfect only issue is cranking up in Reverse.....do anyone know what the problem may be????????
I didn't remember what year(s) were console only, but if yours in on the column that's easy to check. Look at the base of the steering column between the brake and gas pedals. On top of the column maybe 6-8 inches from the floorboard/firewall. If the switch is there you'll see it with the wires attached to it. I don't remember for sure, but think its held on by two small screws that a 5/16" or 1/4" wrench fits, it's been a while since I messed with one of these but I believe if you loosen those two fasteners you can move the switch side to side. If I'm remembering this right that will move where you can start the car. If you can't find it or our comments aren't clear make another post and we'll try to walk you through it. John
Thanks for the confirmation Randy!
thanks guys okay but im a lil lost...sorry im new at this...but is that the pic of the steering wheel or is it towards the bottom of the floor?....my cutlass has the console shifter...should it be located somewhere by it?????? also the car goes into gears good its just when cranking it up i have to put it n reverse
oldspackrat
November 17th, 2014 06:31 AM
