help ,neutral safety switch
hi, would be happy with any input with this problem.i have tried 2 new nuetral saftey switches ,but when i run the shift threw the gears , they keep blowing fuse in the fuse panel, i notice the generater dash light is always on,it goes out to when fuse blows, i have to old switches when i pit them in ,the back up lights work fine , i have adjusted the new and old switch with the little rod you put in the hole when it is in the drive position ,like the manual says. how can something so simple ,be such a pain , maybe i should just put a toggle swich , hate to, any way thanks very much , will.
more symptoms.
started car today,and when i went through gears, when i hit reverse , the generator light came on very dim.neutral it went out,drive it came on bright.also i did not put a new fuse in yet,at this time when i turn key on ,no light , if i put new fuse in , when i turn key on ,i have a light , and it will spark at the nuetral switch when i go into reverse, i don,t know ,it could be worded better, but still any ideas would be appreciated, thanks ,will.
Both your neutral safety and your backup lights operate off that switch assy. The 2 purple are the neutral safety and I believe the lt grn and dk green/ wht wires are your backup lights. I would isolate the 2 circuits for now and concentrate on the purple wires to get your neutral safety system working first.
Then start working on the backup lights. do you have a wiring diagram.
click on this link:
Its the last 2 towards the bottom of the page.
http://www.oldcarmanualproject.com/t.../oldsindex.htm
click on this link:
still no luck!
well i got the car to start in park and nuertal, now ,but when i go to shift by reverse ,i can see and hear a spark inside the nuetral switch, i don,t understand how this can be cause when i put jumper wire in the two green wires the back up lights come on, maybe a defective switch ,but 2 new bad switches in a row, from different stores,also when i put the old switch back in,backup lights work fine, just won,t start in park, took one of the old switches apart cleaned ,and can,t see any thing wrong, any sugestions. thanks will.
Isn't there a solenoid on the switch pitch? The solenoid or the wires going to it could be shorting to the frame/chassis.
Does the trans physically shift correctly into and out of all the gears?
The fact that the back up lights work with out blowing a fuse would seem to indicate that they aren't the problem.
hi, i don,t have an amp meter, will have one soon , so i took fuse out of the fuse panel,that says trans on it.i hooked up volt meter to the plug for back up lights,the two green wires, and there was a 8 volt reading on the gauge, reversed wires and need went below 0, put fuse back in and the gauge went up to 100 . mean while generator light is on all the time as long as a good fuse is in that trans spot,and the transmission shifts perfect in and out of the gears,also the generator loight goes brighter when starting car, then goes back to just being on after you let go of key, i thank all for the input, will.
dhartley72
Jun 4, 2010 01:51 PM
