Help I.D. this connector... Please!
Old Aug 19, 2011 | 03:58 PM
Murco's Avatar
After completing the engine and transmission it's time to turn my attention to the engine compartment and wiring. I've already broken and fixed 4 connectors, jeez these wires are brittle! Anyway, I came across this connector hanging down under the brake booster and cannot figure out what it goes too. It's rubber or plastic (kind of hard to determine) and has 2 slots in a "T" configuration. I do know it isn't the brake switch from the prop valve... Anybody?? Thanks!
Old Aug 19, 2011 | 04:02 PM
Oldsmaniac's Avatar
What car is this....1st pict too blurry.....sorta resembles the backup light plug under hood for 4speed car.
Old Aug 19, 2011 | 04:06 PM
Murco's Avatar
Sorry, it's a 1972 Cutlass Supreme 350/Automatic....
Old Aug 19, 2011 | 04:28 PM
mmcilroy's Avatar
I believe it had something to do with a transmission other than the TH350. I think it was for the 400
Old Aug 19, 2011 | 04:31 PM
TripDeuces's Avatar
It looks like the downshift connector for the plug on the drivers side of a TH400
Old Aug 19, 2011 | 05:35 PM
oldsconv's Avatar
Agree with TH400. One of of the two slots in the rubber plug is for downshift and the other for the TCS switch. Not sure about 72, but I am guessing the wire harness was the same for different engine/tranny combos and this plug would be taped back into the harness (hidden) at the factory if it wasn't needed.
Old Aug 19, 2011 | 06:53 PM
Murco's Avatar
Awesome, thanks so much for letting me know I wasn't nuts!
Old Aug 19, 2011 | 07:39 PM
Originally Posted by Murco
... thanks so much for letting me know I wasn't nuts!
Not so fast... Nobody here said you weren't nuts.
Old Aug 20, 2011 | 01:45 AM
svnt442's Avatar
It the wire black with an orange stripe? That would be for the kick down on a TH400 for sure then. The other wire would be green for the TCS. If it's been pulled out you had better keep an eye out for it because that green wire is hot all the time the car is running.
Nop
Jan 7, 2014 05:58 AM
aquabird
Oct 2, 2013 10:34 PM
tarheeldoc
Jun 3, 2009 06:42 AM
woodie582
Nov 7, 2008 01:07 PM
drtdobber
Feb 14, 2007 01:16 PM
