Pls help ID 2-prong red/orange connector
Old January 7th, 2014, 01:56 AM
Nop
2-stroke 1-cylinder guy
Nop's Avatar
Hi!
I found a 2-prong connector dangling around my steering column I cannot find a mate for. I also can't seem to find it on my A-Body wiring print out.
Everything electrical works, so it can't be very important - nevertheless I'm curious.
Nop is offline
Old January 7th, 2014, 03:33 AM
I can't say for sure, but those are the colors of the wires that normally supply the power window relay.
MDchanic is offline
Old January 7th, 2014, 04:38 AM
Nop
Nop's Avatar
Ah, thanks.
My guess was clutch switch or power top - but I have no clutch and no power top. On the other hand I don't have power windows either. Looks factory installed to me, but the whole harness might have been swapped somewhen.
Maybe it speeds me up cranking the windows when I touch the plug to my tongue...
Nop is offline
Old January 7th, 2014, 05:23 AM
oldspackrat's Avatar
If your car had a th400 trans. that connector went to the electric down shift switch that would be mounted on your gas pedal. All cars came with that connector. Just tape it up out of the way.
oldspackrat is offline
Old January 7th, 2014, 05:39 AM
Nop
Nop's Avatar
Originally Posted by oldspackrat
th400
Ha! As soon as you know what to search for...
https://classicoldsmobile.com/forums...tml#post516365
Thanks!
Ed: And it's orange and pink.
Nop is offline
Old January 7th, 2014, 05:58 AM
Doh.
Serves me right for answering first thing in the morning.
MDchanic is offline
toymobile
June 13th, 2015 08:44 AM
droptop66
May 1st, 2015 10:27 PM
wisniows
February 2nd, 2014 10:40 AM
Zr1bandit
October 7th, 2013 12:13 PM
jugdish
August 18th, 2011 09:57 AM
Quick Reply: Pls help ID 2-prong red/orange connector
