HEI Help with ICM
Old Nov 19, 2023 | 05:32 PM
ben442's Avatar
HEI Help with ICM
www.youtube.com/watch?v=F2yEu1g5trw
Found this video on YouTube and CO from CopperCutlass
I'm having some problems determining If I have spark or not.
455, new build on engine stand, Proform Distributor with new Cap, Rotor, Coil and ICM
Did the same test as in the video and had the same result.
Tested the coil - OK
Tested the pickup coil - OK
Engine at TDC on Number One cylinder, Rotor pointing at Number One cylinder on Compression stroke at about 10degrees before TDC
New MSD wires tested - OK
Distributor has confirmed 12V constant with main power ON.
All grounds test good.
Rolled engine over with start button - plug wire connected to sparkplug not installed and grounded to the block
NO SPARK
Is there a multimeter test I can do to check the ICM ?
Old Nov 19, 2023 | 06:09 PM
MPSax's Avatar
Does the distributor lose power when cranking?
Maybe try these steps. Will need a helper to crank.
Old Nov 19, 2023 | 07:49 PM
gs72's Avatar
72Cutlass S
You can’t ground the plug wire. There has to be a 1/4 to 1/2” gap to ground for the coil to arc.
Old Nov 20, 2023 | 03:23 AM
MPSax's Avatar
I prefer using these to test spark
Spark Plug Tester Light
Old Nov 20, 2023 | 05:05 AM
x2 on using a test light.
Old Nov 20, 2023 | 11:48 AM
Just hold the wire while someone cranks the engine...
Eckat0100
Jul 5, 2023 09:46 PM
ProfVanNostrand
Jan 4, 2023 10:59 AM
75royal88
Dec 12, 2021 02:56 PM
Oldser 1
Jun 28, 2014 07:46 PM
redrider3304
Jul 2, 2010 09:20 PM
