Headlights Work Intermittently
Old Nov 19, 2023 | 04:35 PM
76CutlassSalon's Avatar
Okay, this should be a "quick one"; I just thought that I would "cover all bases" since I always end up with the weird problems:
The '76 Cutlass Salon has headlights that sometimes will not turn on until I pull-push the **** and turn it to and fro several times. This would seem to be an obvious switch problem, but is there anything else that y'all can think it might be? I ask only because this is now our only dependable vehicle and I don't want my wife to be caught out at night with no lights . . . or worse, have them turn off while she is driving at night.
Jeff
Old Nov 19, 2023 | 05:00 PM
It most likely is the switch.
Old Nov 19, 2023 | 05:07 PM
66_Jetstar's Avatar
It could also be a bad dimmer switch. Next time they don't turn on, cycle the dimmer switch a few times to rule it out.
You could also check for voltage at the dimmer switch if you want to be more precise.
Old Nov 20, 2023 | 03:55 PM
You may be right; the dimmer switch is on the column in our Salon, and it has caused "no lights" problems before. Thank you for reminding me!
Jeff
jozw30
Jun 17, 2022 12:18 PM
4SPEED67
Jan 18, 2019 06:06 PM
68cutlass455
May 13, 2018 10:18 AM
jpc647
May 18, 2013 02:08 PM
mike623
Jan 20, 2011 12:57 PM
