1967 Cutlass/442 lights
Old Jan 2, 2019 | 09:44 AM
4SPEED67's Avatar
I am working on the restoration of my 67 Cutlass and my question is - are the outside front turn signal lights suppose to be on when the headlights are on or only work when the turn signal is activated? please advise
Old Jan 2, 2019 | 10:15 AM
The front signal/parking lights only come on steady when the headlight switch is pulled to the first click. When the headlight switch is on or selected in the off position they only light if the turn or 4ways are activated.
Old Jan 2, 2019 | 12:23 PM
To clarify a little, there are TWO filaments in the 1157 bulbs, one for the turn signal circuit and one for the parking light circuit. The turn signal filaments are independent of the headlight switch and work when you turn the turn signals on. The park light filaments come on only when the headlight switch is in the park light position, as Eric noted. Front park lights were not required to stay on with the headlights until the 1968 model year.
This question comes up about once every six months, usually from people who were not alive when these cars were new.
Old Jan 3, 2019 | 04:22 AM
4SPEED67's Avatar
thanks for the clarification
Old Jan 3, 2019 | 11:34 AM
Lonnies Performance's Avatar
Once the safety people determined that you needed side marker lights, the parking lights also stayed on.
I remember doing the same thing on my '66, thinking something was wrong with the light switch.
My father promptly said it was 2 years too old for that.
Old Jan 4, 2019 | 09:25 AM
4SPEED67's Avatar
that is where the confusion started - my 68 442 has them on and the 67 has them off so it got me thinking.
Old Jan 4, 2019 | 04:32 PM
If you want them to be on the same as the 68 you can jumper the parking light switch terminals to also come on with the headlights.
Old Jan 4, 2019 | 04:41 PM
Not really the right way to do this. The headlight circuit is completely separate from the park and tail light circuit and should stay that way. What you need to do is to swap out the headlight switch and harness connector for 1968-up parts.
Old Jan 18, 2019 | 06:06 PM
I ran into this on my 67. Thing mustered 1 park light and 1 of 4 taillights upon initial power, and the light went out when the headlights, one T-3, mounted sideways, high beam only, came on. Took an hour or so of work to get everything on.
Swisspeter
Oct 24, 2019 05:13 PM
1972 "U" code
Jun 16, 2016 04:25 AM
toppertopper
Jul 15, 2014 04:07 PM
jpc647
May 18, 2013 02:08 PM
Mak
Jul 27, 2011 08:39 AM
