1972 cutlass marker lights on
Old Jun 14, 2016 | 02:55 AM
1972 "U" code's Avatar
I just purchased a 72 supreme and noticed that with key on and when running
That marker lights are on and if I turn dimmer switch front blinker also get
Brighter. Bad ground or headlight switch??
Don't think I should have any markers until
Headlight switch pulled out. Just ordered chassis manual
Any help appreciated Dave
Old Jun 14, 2016 | 06:53 AM
The side markers will flash with the turn signals, so if there's a problem with the turn signal switch, that might cause them to come on with the key, but so would your turn signal lights. In any case, there is no connection between the dimmer rheostat and the park lights or turn signal circuits. The only place those circuits are even close is in the headlight switch, so either someone has mucked with the wiring or the headlight switch has an uncommon failure.
Old Jun 14, 2016 | 09:01 AM
Thanks for the info. It is strange. If I turn the headlight switch in the dash clockwise the 2 lamps in
The bumper get brighter. If it turn it counter clockwise until just before dome lights
Kick on it's dull glow you can see from the bulbs. The marker lights I thought would only
Go on when it is pulled out to first position or when headlights are on I position 2. Going to double check chassis ground later
Old Jun 14, 2016 | 09:10 AM
Octania's Avatar
Dash pods should have a ground strap to each pod I believe.
bare braided wire at aft end of RH head to firewall
Battery (-) post 10g or so to radiator support
Headlight sw also presumably has a gnd strap in order to activate the courtesy lites
CSM will have a color wiring diagram.
Old Jun 14, 2016 | 09:33 AM
The problem that you have is a problem that is impossible.
This means that the wiring of your car has been modified in some way, whether intentionally, or by accident (such as melted insulation in a harness).
Old Jun 14, 2016 | 10:04 AM
^^^This. As I noted above, this is not the usual bad-ground-for-the-1157-bulb problem. I've actually had a lighting issue that ended up being an overheated connector and melted wiring at the headlight switch. It was an 86 Chevy truck, but that's pretty much the same switch.
Old Jun 16, 2016 | 03:11 AM
I have removed aftermarket tach and all radio wires as they were all over.also wanted
Factory tach to run instead. Fuses checked,ground to radiator support cleaned.
Now ready to start over.waiting on chassis manual. Only other wires are for msd ign
Ant tach adaptor. Ground to radiator support,white to msd box,red to power,purple to
Brown tach wire.
Regarding side marker lights and front blinker lights they are on faintly but will adjust
With intensity when turning dimmer on headlight switch.havea new ac delcoone ordered
Any other ideas appreciated thanks Dave
Old Jun 16, 2016 | 04:25 AM
Other ideas? Get in there and find out where the short is. Two conductors are touching which should not be, likely a grey and a brown.
First places to look are the headlight switch plug and any point in the dashboard harness that contains the heavy orange wire to the cigarette lighter, which tends to short to ground, overheat, and melt, creating odd cross-connections inside the harness.
ctrain22
Aug 22, 2014 03:14 PM
deadeyejedi
Aug 5, 2014 10:36 AM
68442
Oct 19, 2013 12:28 PM
Oldssupreme
Feb 28, 2013 10:25 AM
cutlassjoe
Sep 4, 2010 08:00 AM
