Instrument cluster lights
Old Sep 19, 2019 | 08:36 AM
Swisspeter's Avatar
Whenever I switch on the lights on my 1963 F85 Cutlass Convertible, the R.H. turn signal pilot light is also illuminated. Not the turn signal itself, just the pilot light and this reacts to the dimmer **** as well. With the lights off everything is as it should be regarding turn signal and pilot light.
Do I have a problem with the printed circuit? Or what else could it be?
Thanks, Peter
Old Oct 23, 2019 | 08:05 PM
rocketscientis's Avatar
63 electric issues
A lot of electrical issuies are a result of bad / missing ground but GMs pin connectors are a close second
Hav a 62 already apart if u need pix or parts
989 721 9432
Old Oct 24, 2019 | 07:39 AM
Swisspeter's Avatar
989 721 9432
Thank you for your advice. I may come back to you for pix, but first I'll have to remove the whole thing.
Old Oct 24, 2019 | 11:11 AM
Electrical issues
Check all grounds & th one that grounds th instrument clusster / circuit board especialy
Good huntin
Old Oct 24, 2019 | 05:13 PM
PatL's Avatar
As others said, anytime I experience the weird electrical events, such as yours, I check that there is good ground. Electricity wants follow the shortest path and goes a routing that creates events like yours. Perhaps the instrument lights grounding is the issue, while I suspect grounds the same way the turn signal pilot light does, via the speedometer gauge.
Had a similar situation with my taillights; turns out during reassembly, never got the bumper bolts fully tightened.
Oldsr4me
Oct 27, 2015 07:49 PM
toppertopper
Jul 15, 2014 04:07 PM
1BOSS83
Jun 11, 2013 04:33 AM
Mak
Jul 27, 2011 08:39 AM
Big Joe P
May 23, 2007 04:29 AM
