MSD Ignition No Spark From Distributor ?
Old Jun 26, 2010 | 09:09 PM
redrider3304's Avatar
Question MSD Ignition No Spark From Distributor ?
Looking for some help with my ignition install. I got a 71 olds cutlass w/455, i just had motor overhauled and put in new pro -billet ready to run distributor PN 8529. kit comes with new wires distributor and blaster coil, i hooked everything up to msd instructions and i have power to to of cap from coil wire and nothing to spark plug wires can anyone help me.
Old Jun 26, 2010 | 11:28 PM
svnt442's Avatar
So are you saying the coil is sending spark to the cap but it's not making it out to the plug wires?
If that's the case then it would have to be something with the cap and/or rotor.
Old Jul 2, 2010 | 09:20 PM
problem solved
After about a day and a half searching for possible problems it turned out to be a bad ground on the coil i hooked up a ground strap to firewall and the beast fired right up thanks for trying to help this issue.
ronetuley
Aug 13, 2013 10:33 PM
f-85
Aug 9, 2013 09:22 AM
chris83
Aug 18, 2012 01:47 PM
69CutlassAlex
Dec 6, 2011 10:14 AM
Redog
Mar 4, 2007 12:28 PM
