Female blower motor resistor plug
Old September 16th, 2015, 10:45 AM
The Bug Man's Avatar
Anyone have the female end for wiring harness that plugs into resistor on heater box.
File Type: png
The Bug Man is offline
Old September 16th, 2015, 11:32 AM
You can get these through RockAuto (or local parts stores - Airtex #1P1042).
You can also use four ¼" spade connectors if you're not concerned about original appearance.
MDchanic is offline
Old September 17th, 2015, 06:59 AM
Damn really ? I should have known ! Just ordered the switch relay for AC from them. THANKS !
Old September 28th, 2015, 12:33 PM
1971 442 BB high blower relay
OK have three out of four positions on the fan working great. No high speed yet. Assume that I have an issue with the High blower relay. Service manual shows it to be on drivers side fender (opposite of horn relay on drivers side). Pretty sure I'm looking at the correct diagram. Not there on my car. Would it be on the heater box or fire wall on passenger side. This is a factory air car and of course I have all the compressor, muffler and plumbing in place so it's hard to see anything in that area. I can live without high speed but I'd like to get this gremlin squashed.
Old September 28th, 2015, 01:08 PM
Locations varied with models and years - what's yours?
MDchanic is offline
Old September 29th, 2015, 06:17 AM
1971 442 455 motor th400 trans
Old September 29th, 2015, 06:50 AM
The relay is usually right near the brake booster.
Follow the heavy wires from the horn relay junction stud.
Find the one that doesn't go through the firewall or down to the starter - it should lead to an inline fuse and then to the high speed relay.
Dumb question: Your car IS an A/C car, right?
MDchanic is offline
Old September 29th, 2015, 08:20 AM
Yep factory air car
Old September 29th, 2015, 08:54 AM
oldspackrat's Avatar
My bet is the fuse going from the horn relay to the high speed fan relay.
oldspackrat is offline
pistonpop
October 26th, 2011 07:30 PM
Beob
February 10th, 2011 04:57 PM
redvettemike
September 6th, 2010 07:06 PM
MJAKS462
July 22nd, 2010 03:44 PM
Texas67olds
November 1st, 2009 12:59 PM
Quick Reply: Female blower motor resistor plug
