Blower Motor Resistor
Old June 23rd, 2009, 05:56 PM
redvettemike's Avatar
There is a blower motor resistor that is in the a/c 'box' on the firewall of my '71 442. My blower motor (new) will only work on the highest fan setting. I have a blower motor relay coming and will try that. If that doesn't work it likely is the blower motor resistor. My local O'Reilly and Advanced parts places don't show that part. Can any of you folks tell me where this resistor (held in by 2 screws) can be purchased. I don't see it in Fusick's. Thanks,
Mike
redvettemike is offline
Old June 28th, 2009, 04:14 AM
As a followup, I replaced the fan relay on this car. This was after looking at the blower motor resistor. You can evidently often times look at these and can see if one of the resistor wires is burned. There are two similar relays on the firewall of this car ('71 442). I replaced the one on the passenger side but the fan problem continued. We took the dash fan switch out and cleaned it. When put back in and switched from one speed to the other you could hear the relay 'clicking'. However, it was not the relay near the a/c box, it was the relay on the driver's side. So we put the new relay over on that side and the fan started working normally. I am not sure what the pass side relay does but it does not controll the blower motor (at least on this car.)
Old June 28th, 2009, 03:40 PM
tim72's Avatar
Mike,
I am having the same issues as you. I am not showing any power at all at the fan motor. Actaully I have had a dead draw on my battery which I was realting to this fan motor issue. I found that I had a bad cell ion a 1 year old battery from Murrays. Well the draw seems to be gone for the moment.
tim72 is offline
Old June 28th, 2009, 10:18 PM
Yellowstatue's Avatar
Cool High speed blower
The relay on the passenger side controls the highest speed of the blower, which is 12 volts direct to the motor separately fused (inline)...the other speeds are obtained by going through the resistors
Yellowstatue is offline
Old June 29th, 2009, 05:07 AM
Lady72nRob71's Avatar
Did this car have rear defogger? It almost sounds like it...
If you have factory defogger, then the lower pass side relay disables high blower speed when defogger is on to limit current draw. The 66A alt would not handle the load of both. Now WHY they put the high speed relay so far from the motor is beyond me... Longer wire runs for a high current device is not a good thing.
The defogger main relay is on the pass side also, but up higher. It will not engage unless the engine is running.
Lady72nRob71 is offline
Old June 29th, 2009, 02:14 PM
Rob: You are correct. The car does have a rear defogger.
Thanks,
Mike
Old July 28th, 2010, 03:43 PM
MJAKS462's Avatar
OK here we go !
Just got a used AC blower motor and resistor in the mail.
My car has no AC box in the engine bay , just the 2 copper tubes from the heater core. So I just want the heater and defrost to work.
Interior heater box , wiring , ducts , switches are all there .
I have a aftermarket ac delete cover ready to go.
One problem is that I dont even know where the resistor goes or what plugs into the 4 prongs that are on it.
the blower motor has a single wire term on it that I do not know what is supposed to plug into it.
and a 1 " hole on the motor casing.(do I need to plug this ?
I can handle installing the blower motor but then what ?
Thanks Guys !
MJAKS462 is offline
Old July 28th, 2010, 09:16 PM
Just the facts...
BILL DEMMER's Avatar
the hole on the blower motor is for cooling the motor itself, it connects via a rubber pipe to a nipple on the heater box. plugging that hole could lead to very early failure of the blower motor due to overheating.
the blower motor resistor mounts into the heater box in the airstream from the blower motor discharge, it mounts there to cool the resistor elements which would burn out quickly due to overheating.
bill
BILL DEMMER is offline
Old July 29th, 2010, 03:04 AM
MJAKS462's Avatar
OK , Thanks Bill , that will get me started. Hopefully the wires for the resistor and the blower are hanging around somewhere.
MJAKS462 is offline
Old September 6th, 2010, 07:06 PM
dunk08's Avatar
bill
by mounting, do i have to drill holes or are there reinforcement clips that i can buy in the market?
dunk08 is offline
1971viking
November 15th, 2011 11:05 AM
pistonpop
October 26th, 2011 07:30 PM
Beob
February 10th, 2011 04:57 PM
MJAKS462
July 22nd, 2010 03:44 PM
Texas67olds
November 1st, 2009 12:59 PM
Quick Reply: Blower Motor Resistor
