erratic timing/hei
Hey guys ,72 cutlass/455/hei. All new internals[proform],recently installed msd-6a ,car runs great,tweaking timing and its moving 4-6 degrees.Im using standerd lite,is fire jumping inside cap ? mr. gasket advance wieghts? please help if your using msd-6a. maybe i shoud have spent that money elsewhere.thanx,BO
no more msd!
thanx guys , everything was good before,so ill eliminate the box, maybe this lesson will save someone else some trouble and some money. by the way ,i saw no performance gain so for 250 i like to feel some diffrence.anybody want to buy a box?? thanx again.BO
Also check the distributor baseplate where the vacuum advance rod mounts into it. I have seen a few of these where the hole in the baseplate was much bigger than the rod on the advance unit. It should be a snug fit. That can cause some timing scatter as well.
thanx for replys, im pretty determined,ill figure it out,then post result.there are 2 many people running 6a box ,somebody has seen this before.im sure its somthing simple.thanx again,BO
THANKS,im in touch w/msd tech now,see how that goes,regardless ,ill post outcome here! oh i removed the box,put old module back in.ran fine.the spark is just so hot it trys to jump any where theres metal.ill get it,BOSMOBILE
joepenoso
Jun 4, 2014 01:56 PM
Vistabrat72
May 16, 2013 08:36 AM
