Don't know part name for power windows
Old Aug 28, 2013 | 10:29 PM
jugdish's Avatar
Hello,
Looking to replace the part shown in the attachment. Window switch plugs into it. Have searched web for part name but unsuccessfully. Anyone know name and possible purchase location?
Thank you
Old Aug 29, 2013 | 03:01 AM
That's the power window switch plug.
If you can't fix it, you'll need to get a used one.
Old Aug 29, 2013 | 07:35 PM
Lady72nRob71's Avatar
If just a broke wire, it is an easy fix.
Find someone into electronics or electrical repair.
Fly me to Seattle and I will do it for a 6 pack!
These are not sold reproduced. Used is the only way, but then you are cutting and resplicing all the wires, not just one.
Old Aug 30, 2013 | 09:23 AM
jugdish's Avatar
Thanks to both of you, appreciate the info. I think there is some corrosion in the connections behind the cover, besides a wire that was pulled out. Will pry apart and get to fixing. Good to know they can't be purchased, but wish they could be. I guess we all have a long list of those items.
Old Aug 30, 2013 | 02:19 PM
2blu442's Avatar
What year/model of car? If you can't fix it I may have a good used one.
John
Old Aug 30, 2013 | 05:16 PM
A dremel tool with the right size diamond cutter and a very light hand will get rid of the corrosion in the contacts efficiently. You want to clean it up, not remove metal.
Old Sep 6, 2013 | 11:42 AM
jugdish's Avatar
It's a 69 delta 88. Only way to get to the connections is to take/tear off the cover. Would rather not, but not a big deal if I do, I suppose.
Old Sep 6, 2013 | 07:03 PM
Put on your engineer's hat and see how the cover can be removed in the least destructive way possible. I am sure there is a way. If you cause some cosmetic damage, it will be hidden, and making the part work again is more important than cosmetics.
If you get stumped, post a clear closeup of what you are working on and we will try to help out!
Old Sep 8, 2013 | 01:35 PM
jugdish's Avatar
Will do, and thank you. I'm starting momentarily and will report back.
matchek
Jun 15, 2015 03:26 AM
socalrs
Aug 14, 2012 11:07 AM
squirell
Apr 13, 2011 05:22 PM
deweirdt
Jul 21, 2009 08:29 AM
rustycarr
Mar 7, 2007 06:24 AM
