Darn tail lights
Old Sep 16, 2018 | 01:49 PM
Rosco920's Avatar
Darn tail lights
Here’s my issue. I have a 72 cutlass vert. My left side tail lights worked, but my right side didn’t. I looked to change the bulbs on right side and saw that they were rotted out. So i got new light socket pigtail and wired them. Soon as buttoned everything back up, my left side continued to work and right side still didn’t. I figured something was crossed so I started over. I rewired the sockets and now my right side works when turn signal is activated and left side doesn’t. No brake lights work nor do they stay on when I will the swith. I am lost for words and feel like I am chasing my tail in a circle lol.
Is there a trouble guide somewhere! Is this a ground issue. Totally pissed owner right now. Any help is greatly appreciated.
Old Sep 16, 2018 | 02:14 PM
Check your ground. It sounds like you have an open circuit after finishing your work.
Old Sep 16, 2018 | 02:15 PM
Do you have running lights? Have you checked the fuse?
Old Sep 16, 2018 | 04:05 PM
Rosco920's Avatar
I got running lights. Both front and tail are working. It’s odd as hell.
Get this.....I went around the bumper to check the screws and one was loose. While that one was loose, the right turns worked but no running lights. When I tightened the screw up, running lights, but no turns or brake lights. Puzzled as hell I tell you
Old Sep 16, 2018 | 04:31 PM
Make sure the lamps are in contact with the contacts in the socket.
grmchne78
Sep 18, 2018 09:01 PM
toronado70
Feb 28, 2016 02:26 AM
73aussie455
Sep 23, 2014 04:10 AM
BoutTime68
Jan 19, 2014 08:29 AM
Sid
Sep 10, 2010 02:33 AM
