Left tail lights Toronado 70
Tail lights are working as normal. At the right side everything is good. Both turn lights and brake lights are good.
At the left side the turn lights and the brake lights dont work. The marker light on the outside of the bumper dont work either.
The turnlight in the front is ok.
Any suggestions.
Tedd
Any suggestions.
Tedd
get your volt-ohm meter out and find out where the voltage is failing to flow
ck that all bulbs are the proper type- 1 contact in 1-wire holder, 2 in 2. In the right way around
anything here been "fixed" lately?
Verify that the bulb holder ground contact has 0 ohms [well, under 1 ohm] resistance to a known ground.
The only thing common there is the ground. Start troubleshooting by running a temporary ground wire from the LH tail light housing to a known good ground.
Oldssupreme
Apr 3, 2015 08:36 PM
