Convertible Top motor - direct battery connection
Old June 19th, 2019, 07:13 PM
70ish's Avatar
Guys,
While i have my car in pieces i have the need to lower the top (so i can weld and work on the windshield). The dash is completely off and all the switches are disconnected. Can i just attach the Red or Yellow to the + of a car battery (while grounding -) and would that work the top motor? or is there a risk that i could smoke the motor? i would think the top motor would only draw the current it needs but jsut curious if anybody else has attempted this?
Once i get the car back together i will post the work as i discovered many nuances with my redo.
Thanks,
Ed
70ish is offline
Old June 19th, 2019, 07:19 PM
That should work, assuming you get the correct polarity. You'll know immediately if you don't as the top will try to go the wrong way.
Fun71 is offline
Old June 19th, 2019, 08:44 PM
Tedd Thompson's Avatar
Or you can disconnect the lift cylinders at the upper end and manually lift the top to the down possession..Tedd
Tedd Thompson is offline
MudEye
August 29th, 2016 07:03 AM
Southern_Hospitality
October 12th, 2011 06:55 PM
October 12th, 2011 08:01 AM
tpawlik
March 19th, 2010 06:06 PM
rutsski
March 12th, 2008 01:39 PM
Quick Reply: Convertible Top motor - direct battery connection
