brake light
Old Feb 16, 2023 | 03:00 PM
GKranig1's Avatar
brake light
When the ignition switch is off, my parking brake light is on ,but it's very dim. It stays on even though the brake pedal is not depressed.Any idea on this issue?
Old Feb 16, 2023 | 03:31 PM
Sugar Bear's Avatar
Bad ground to the instrument cluster???
Is the negative on the battery grounded to the fender or just the engine?
Old Feb 16, 2023 | 04:12 PM
GKranig1's Avatar
Battery is grounded to motor,motor grounded to firewall,body grounded to frame
Old Feb 16, 2023 | 05:10 PM
rocketraider's Avatar
Oldsdruid
Year and carline?
Some years and models have a small gage wire running from battery (-) terminal to the fender or radiator core support.
Others have a metal grounding plate on the back side of the instrument panel.
Go underhood and you'll see a tan wire connected to the brake distribution block. Pull the wire off its connector and see if the light turns off. If it does there's a wiring issue between the block and the warning lamp.
Then look at the parking brake assembly underdash. You'll see another tan wire connected to a plunger switch on there. Jiggle that wire and switch and see what the lamp does. That will isolate the switch as a cause of the dim glow.
Old Feb 16, 2023 | 05:51 PM
GKranig1's Avatar
1972 442,thanks for the info,i'll try them.
WHIPOLDS
Nov 30, 2022 07:28 AM
pettrix
Jun 9, 2021 03:36 PM
ddx77
Dec 3, 2011 04:18 PM
jo75olds
May 7, 2011 08:20 AM
155thINF
Sep 12, 2006 05:03 AM
