Blower motor testing
Old May 19th, 2014, 11:10 AM
Macadoo's Avatar
Question Blower motor testing
I've been looking for the answer to this all day. Nothing online and nothing in the CSM that I can find.
I want to test my blower motor before I put the inner wheel well back in but can't figure out how to hook it up. Purple wire is the power feed (through resistor) but where do I ground it? I'm using the charged car battery for juice and jumper cables off an old battery charger. I watched Rob's video but I can't make out the connection.
Thanks guys.
Macadoo is offline
Old May 19th, 2014, 11:18 AM
RandyS's Avatar
I believe the housing is the ground. (not unlike a horn)
RandyS is offline
Old May 19th, 2014, 11:22 AM
Macadoo's Avatar
So, power from bat to resistor. Negative bat lead to housing? I'll try it.
This isn't much help.
[IMG][/IMG]
Macadoo is offline
Old May 19th, 2014, 11:30 AM
Macadoo's Avatar
Okay, got it. Power from batter to resistor but ground from batter to resistor housing. So is that what I screw the ground strap to for installation, the resistor mounting screw? I'll get a pic in a sec.
Macadoo is offline
Old May 19th, 2014, 11:36 AM
Nop
2-stroke 1-cylinder guy
Nop's Avatar
Faster!
Wise! (No questions, please! Search the "What have you done to your Oldsmobile today" thread...)
Ground comes through a short cable from the firewall nearby, see image. Obviously the plastic/fibre air duct is not ground.
Nop is offline
Old May 19th, 2014, 11:37 AM
Macadoo's Avatar
[IMG][/IMG]
Macadoo is offline
Old May 19th, 2014, 11:39 AM
Nop
Nop's Avatar
Yes, "to here". And make sure it's really bare metal on ring of wire, new painted fan housing and all parts.
also make sure it'll stay that way.
Nop is offline
Old May 19th, 2014, 11:45 AM
Macadoo's Avatar
Thanks Nop. And may I say...Dayum, you've got a nice looking ride!
Macadoo is offline
Old May 19th, 2014, 11:55 AM
Nop
Nop's Avatar
Thanks!
I was about to cut a hole in my inner fender but decided to rip it all apart again when the ground rattled loose after 2 days....
Nop is offline
Old May 19th, 2014, 01:13 PM
Macadoo's Avatar
Can't blame you for wanting to cut a hole. I don't want to go through this again. Motor tested fine but I found a bad leak. Seems the caulk fell out of place when I was putting the box back on. Of course it was right against the inner fender. Nothing like caulking with a screwdriver
Macadoo is offline
redvettemike
September 6th, 2010 07:06 PM
Olds64
December 12th, 2009 02:49 PM
Texas67olds
November 1st, 2009 12:59 PM
Redog
November 30th, 2007 06:22 AM
Luckyme1870
Aurora
July 26th, 2007 05:05 AM
Quick Reply: Blower motor testing
