Alternator Upgrade
Old Mar 5, 2020 | 11:14 AM
RotternEgg's Avatar
Alternator Upgrade
Hi all
I'm upgrading my alternator on my 69 Cutlass to a CS130 as I need more amperage. I have found a 'resistor' in the wiring, anyone know whats this is for?
Old Mar 5, 2020 | 11:21 AM
That is a diode. It's like a one way valve that allows current to flow in only one direction.
Old Mar 5, 2020 | 11:30 AM
RotternEgg's Avatar
Thank you, any particular reason for it being on the gen lamp light wire?
I think its the gen lamp wire anyway, I havent explored it yet.
Old Mar 5, 2020 | 12:45 PM
JohnnyBs68S's Avatar
That's definitely a hack job, didn't come from the factory that way. That little diode is probably rated for only 1A. I'm not that familiar w/ the wire color codes so I can't tell what it is doing there, but I'd try to remove it if possible and clean up those splices. If you are upping the amperage of your alternator, you'll also need to beef up all wiring carrying the alternators output current (like the big red one bolted to the terminal on the back of the alternator). The factory harnesses were not designed for currents larger than what the factory offered in the alternator. Be careful and don't start a fire.
Old Mar 5, 2020 | 01:54 PM
stellar's Avatar
stellar
It is to prevent feedback to the ign system from the alternator. The car may continue to run after the key is turned off if it is not there. It is common when the alternator has been changed from a external regulator to an internal regulator. It is fine in the system in there now.
Old Mar 5, 2020 | 06:39 PM
It’s not factory, but it’s needed for some aftermarket ignition systems. Without the diode the engine will continue to run with the key off. I would definitely repair the harness, the quality of wiring repair is pretty lousy.
Old Mar 5, 2020 | 10:35 PM
RotternEgg's Avatar
Thanks Guys.
I will be tidying up the wiring, you should see some of the other cables, I got cables stuffed everywhere, some not connected to anything, I'll leave it in place albeit a tider job and I'm increasing the BAT cable gauge
Thanks once again
Aaron
Bernhard
Jul 3, 2019 11:35 PM
Steven Hall
Mar 19, 2019 05:34 PM
capstoneclub
May 4, 2013 08:39 PM
my442conv
Sep 15, 2011 09:39 AM
gearheads78
Sep 3, 2008 11:12 AM
